Go to Post God Bless the referees. - MooreteP [more]
Unread 09-02-2015, 19:33
Potatoes's Avatar
Potatoes Potatoes is offline
AKA: Eric Wittmann
FRC #5136 (Mecha Pirates)
Rookie Year: 2014
Potatoes is an unknown quantity at this point
Encoder Help
Hello, this year our team is using this encoder to measure our robot's movement.
http://usdigital.com/products/encode...rotary/kit/E4P
We are having trouble programming it in LabView. Below are screenshots of our current code in begin and teleop, mostly just copied from the encoder example. It's not reading any values from the encoder, and we've double checked our wiring on the robot. Is this year's LabView different for encoders?
ID:	18247  Click image for larger version
Unread 09-02-2015, 19:38
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Encoder Help
Does the original stand-alone example work with the encoder?
If that doesn't work, then you'll know it's not your code either.
Your code looks simple enough unless there are some unusual control values involved.
Unread 09-02-2015, 22:13
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Encoder Help
We can't see what values you have set the controls to on the front panel of Begin. Is there a reason you didn't make them constants instead of controls?
