Go to Post If you can't make them fit on the robot, then those features don't really add much value. - Cory [more]
Unread 09-02-2015, 20:23
JOEL340 JOEL340 is offline
340 Alumni, Mentor for 5030 and 340
FRC #0340 (Greater Rochester Robotics)
Rookie Year: 2007
JOEL340 will become famous soon enough
Excel Help!!
I was wondering if anybody could help me with some excel work. I am trying to make a spread sheet for scouting and have everything done except one part. I have a sheet where I can change the matches, on this sheet there are three cells that I want to change to a default number of 0 when I change the match number. Any help would be nice, Thank you!
TEAM 5030
2015-Present Mentor
New York City Regional Champions 2016
TEAM 340
2014-Present Mentor
New York Tech Valley Regional Champions 2015
2010-2013 Student
Buckeye Regional Champions 2012
Chairmans Award 2010, 2011, 2012, 2014
Engineering Inspiration2012, 2014
Unread 17-02-2015, 01:15
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Excel Help!!
After looking at a couple StackOverflow posts [1] and [2], I think some Visual Basic might be easiest.
I've attached an .xls which does the job (created from Excel 2003). The code is set to change cell B2, C2, and D2 to "0" whenever cell A2 is edited. The code is as follows:
Code:
Private Sub Worksheet_Change(ByVal Target As Range)
    If Not Intersect(Target, Target.Worksheet.Range("A2")) Is Nothing Then
        Target.Worksheet.Range("B2").Value = 0
        Target.Worksheet.Range("C2").Value = 0
        Target.Worksheet.Range("D2").Value = 0
    End If
End Sub
In the event this doesn't work in you version of Excel, let me know. I have no good idea if this is "clean" VBA code, but it works. Go and change the cells as appropriate.
PS: you'll probably have to enable macros upon opening the file.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
