pic: Team 701's Intake Teaser
Re: pic: Team 701's Intake Teaser
Greetings from 2169!
I was just wondering where you sourced those miter gears? We need some with a 1/2 inch hex bore but cannot seem to find them. Thanks! |
http://www.wcproducts.net/217-3344 |
It actually works much better than I expected for low loads. Link here due to massive photo. *not for the feint of heart |
If both our teams qualify for champs we need a picture with our sketchy intakes ![]() |
Looking good, Frank. Can't wait to see it out at CVR. Curious though - what is the need for the 90 degree angle mounting for the planetary? Seems a little overkill for an intake.
We ran into some vertical clearance for the elevator grabber ourselves while figuring out our versaplenetary mounting. IT's not easy to find a way to tranfer power from the versaplnetary output to the wheel while keeping things short. I considered bevel gears but dropped it due to machining issues.
The Bevel gears are just standard Martin Gears off of McMaster. We cut the hubs off of them and broached a 1/2" hex bore in them. Put the whole assembly on some polycarb to be flexible going over the scoring platform or when we run into stuff. Seems to be holding up well so far. |
