Thread Tools |
Rating:
Display Modes |
An ironic choice of phrase ![]() |
Re: What motors are you using for your lift?
We are using 1 mini-CIM connected to a 35:1 versaplanetary with a 15T sprocket driving a #35 chain to our elevator carriage. It seems to have the power and speed we were looking for.
2 gearboxes, each with a CIM in a Banebots planetary with a 16:1 reduction. It lifts at a speed that satisfies us and can easily lift 6 totes and a container.
Two CIMs into a standard ratio AndyMark RAW Box on a 15T #35 sprocket (PD = 1.79").
Two CIMs in a 12.75:1 toughbox.
We did the math on one CIM and decided we liked two better. |
Our team is using a threaded rod setup.
We used two mini-CIMs on a Toughbox-Mini gearbox. It's more than enough for that particular purpose: we can lift six totes and a bin with no trouble. |
We are using a single Bag motor and some weight compensation trickery. It seems pretty unique compared to everyone else's specs, but it fits our strategy very well. We'll see.
We used two CIMs with a vexpro single speed double reduction with the stock (slowest) speed. Then it goes from a 22 or 18t sprocket to a 72t sprocket. I am confident that mini CIMs would be plenty powerful if you don't have the motors to spare. This gives a ridiculous amount of torque so we can lift rather quickly compared to lifts that use smaller motors.
Edit: We don't use a spool, a continuous loop of chain lifts the arm things and that is driven off the shaft with the 72t with 22t sprockets. Last edited by PowerfulKitty : 10-02-2015 at 16:09. |
