Go to Post Leave it to CD to misconstrue a joke this badly. - connor.worley [more]
Unread 10-02-2015, 09:48
RenanTroia RenanTroia is offline
FRC #1382
RenanTroia is an unknown quantity at this point
Corner
Can someone tell me if there is something in the manual that forbids corners like the one that appears in the picture? Or if have some specification about that?
Unread 10-02-2015, 09:50
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Corner
We would need more specific knowledge on its intended use and location before we could answer that.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 10-02-2015, 10:09
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
Rookie Year: 2013
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
Re: Corner
That there looks like a wedge used to force those totes from the walls. Just a guess... not a bad idea.
Unread 10-02-2015, 10:27
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Corner
Rule R7 is probably the one that applies here.
Unread 10-02-2015, 12:23
FRC #1382
Re: Corner
The intention of the corner is facilitate to get the toten. And it is positioned in front of the frame.
Unread 10-02-2015, 12:44
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Corner
Renan,
In years with defined bumper rules, this would not have been able to meet the "bumpers must cover a minimum of 8" either side of a corner" rule. There is no bumper requirement this year. No one can make a ruling based on a picture, the Inspector at your event will check this over. From the picture, I don't think this violates any rule. However as Jim has pointed out, this will be evaluated under R7 and will be observed for any damage to field elements while in competition.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 10-02-2015, 13:35
AKA: Rich Lester
Rookie Year: 2013
Re: Corner
Good point, didn't think about damaging the field elements. PRetty sure our robot this year would put it through a wall. :/
Unread 10-02-2015, 13:38
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Corner
R7 or R8 are the most likely issues, and they are definitely subjective, based on how they are oriented and actuated and used. We had a rather more wicked looking hook on our Ultimate Ascent climber, and didn't raise any eyebrows.
Unread 10-02-2015, 14:27
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
Team Role: Coach
Rookie Year: 2012
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
Re: Corner
R7
Protrusions from the ROBOT and exposed surfaces on the ROBOT shall not pose hazards to the ARENA elements (including
the LITTER, RECYCLING CONTAINERS and TOTES) or people
if the ROBOT includes protrusions that form the “leading edge” of the ROBOT as it drives and have a surface area of less than 1 in.sq , it will
invite detailed Inspection. For example, forklifts, lifting arms, or grapplers may be carefully Inspected for these hazards
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 11-02-2015, 00:12
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Re: Corner
I noticed that because the totes have slanted sides, totes that are next to each other are already spaced enough to fit a wedge that has a point with a much larger and safer radius. I'd recommend bending it so that the end of the wedge is not a point, but rather a flat surface, perhaps .25 inches wide so you don't get inspectors thinking its' too sharp. Basically, make your wedge into a trapezoid instead of a triangle by making the tip blunt and flat.
Unread 11-02-2015, 01:27
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Re: Corner
Point A) I don't see anything "wrong" with it... it looks like a nicely rounded leading edge. So long as it doesn't damage field equipment, I wouldn't have a problem with it.
Point B) I won't be doing tech inspection at your event so my answer is not particularly useful.
I think the bottom line is that as long as it doesn't damage the totes or the field, you should be okay.
Jason
