Go to Post its ok to have opinions- but why attack everyone elses who differs. - stevek [more]
Unread 02-10-2015, 11:10 AM
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Rookie Year: 2010
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
NetworkTables Issues
Hello,
I'm currently having some issues with NetworkTables. I've created a standalone-application for vision processing and would like to send data to the RoboRIO. I keep getting an exception saying that the key is not defined/it can't access it -- I fear it is not being created and am unsure if I'm doing something wrong. Here's what I'm doing.
Vision Processing Application:
Code:
public static NetworkTable outputTable;
//main thread of program
public void run() {
NetworkTable.setClientMode();
NetworkTable.setIPAddress("10.25.59.2");
outputTable = NetworkTable.getTable("vision");
// semi-pseudocode, if it finds the tote it invokes that function with those parameters
if(foundTote) {
outputTable.putBoolean("found_tote", true);
Robot Code:
Code:
public static NetworkTable visionTable;
// robotInit in Robot.java
public void robotInit() {
visionTable = NetworkTable.getTable("vision");
// SmartDashboard syncer/setter function
public void sendSensorData() {
try{
SmartDashboard.putBoolean("Found Tote", visionTable.getBoolean("found_tote"));
} catch(Exception e) {System.out.println(e);}
I have a feeling that I may need to do something else but, due to the limited documentation, I cannot find out what I'm doing wrong. I'd love to hear your ideas.
Thanks.
Unread 02-10-2015, 02:22 PM
amreuland's Avatar
amreuland amreuland is offline
Overworked Insomniac
AKA: Austin
FRC #2583 (Westwood Robotics)
Rookie Year: 2013
amreuland is on a distinguished road
Re: NetworkTables Issues
You should have a default value with that getBoolean. Also, if the rio starts up before your program, its going to get an error, because your client has not set the value yet.
Code:
getBoolean("found_tote", false);
Use that to keep from getting error, and make sure your client is actually connecting.
RoboLib - An enhanced FRC Library http://robolib.github.io/
Lone Star Match 85 - Arena and Robot Video https://www.youtube.com/watch?v=5tgJZ-s3dIQ
Unread 02-11-2015, 04:30 PM
Ozuru's Avatar
Rookie Year: 2010
Code:
Thank you. I've added that default case now and I'm still having this error -- they're simply not communicating. Any ideas?
