Go to Post "The only constant is change" is a hint that probably applies to every season of FIRST. - Chris is me [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 10-02-2015, 12:16
baldenb's Avatar
baldenb baldenb is offline
AKA: Ben Balden
FRC #1540 (The Flaming Chickens)
Rookie Year: 2012
baldenb has a spectacular aura aboutbaldenb has a spectacular aura aboutbaldenb has a spectacular aura about
RS775 In Drivetrain?
Has anyone ever used RS775s in a drivetrain before? Due to their similarity to a minicim in terms of power, and their lightness, they seem like a viable option for a non-defensive game where stalling in a pushing match is out of the question. including a vexpro CIM-ile gearbox, a RS775 weighs about a pound, which is half what a minicim weighs. If anyone has experience with using 775s in a drivetrain or similar application, I would appreciate your insight.
Unread 10-02-2015, 12:25
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: RS775 In Drivetrain?
Teams have burned out 775 motors trying to use them in drivetrains before. I don't know if anyone has successfully used them. (The power level is similar, but the MiniCIM has more torque and can handle being run at stall/high power levels longer.)
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 10-02-2015, 12:30
baldenb's Avatar
AKA: Ben Balden
Rookie Year: 2012
When teams have burned out 775s, has it been because they were stalled or just under heavy load for long periods of time? Is a 775 designed for less continuous use than a minicim, or just not designed to be stalled?
Unread 10-02-2015, 12:37
Kyler Hagler's Avatar
Kyler Hagler Kyler Hagler is offline
Jack of all trades
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2011
Kyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura about
We used them briefly last year. We had a 3 CIM Ball Shifter with 2 CIMs and an R775 on each side. We didn't see much performance boost and they became hot and didn't really work out well in our setup. This isn't to say they wouldn't work in your application but we just didn't see the need for them. As to the discussion about them burning out we never had that problem but i could see it happening if pushed continuously for very long periods of time.
Kyler Hagler - 3310 Alumni/Mentor
Black Hawk Robotics Team 3310
2012 Dallas West Regional Winner
2013 Dallas Regional Winner
2014 Colorado Regional Winner
2015 Hub City Regional Winner
2016 Arkansas Regional Winner
2016 Hub City Regional Winner
Http://Team3310.com
sodizzle's Avatar
sodizzle sodizzle is offline
AKA: Brandon Sidoti
FRC #1023 (Bedford Express)
sodizzle is a jewel in the roughsodizzle is a jewel in the roughsodizzle is a jewel in the roughsodizzle is a jewel in the rough
I've heard of them being used in a gearbox that also has a CIM or two in it. Not sure how much benefit you get out of it though.
Proud alumni of 1023
http://www.chiefdelphi.com/forums/ximage.php,qtype=sigpic,auserid=64794,adateline=13  93953662.pagespeed.ic._coysrOV9p.jpg
Unread 10-02-2015, 12:41
baldenb's Avatar
AKA: Ben Balden
Rookie Year: 2012
We are considering using them in place of minicims in our drivetrain, primarily to save weight.
Unread 10-02-2015, 12:45
cgmv123's Avatar
AKA: Max Vrany
Rookie Year: 2011
That is not something I would recommend.
Unread 10-02-2015, 13:01
sodizzle's Avatar
AKA: Brandon Sidoti
I specifically meant when paired with two other CIMs. But as others mentioned it does have some benefits that I was unaware of when in that configuration.
Unread 10-02-2015, 13:11
protoserge's Avatar
protoserge protoserge is offline
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
The RS series motors need active cooling to keep the enamel on the commutator shaft from melting. This is achieved in stock form by an internal fan and air ducts at the front and rear of the housing. The RS series motors are intended for power tools and R/C cars where they have plenty of air movement and are typically driven in one direction for a continuous period of time (not fast forward-reverse motion like the FRC robot).
The CIMs and MiniCIMs have a higher thermal mass to dissipate the heat and typically use the gearbox as a heatsink. The large mating surface area helps conductive heat transfer and the overall larger system mass provides more heat capacity. During extended runs, you will likely notice the housing of both the gearbox and motor are warm, but not necessarily hot, unless there is high friction due to under/over-greasing of the transmission or improper assembly or other motor failure mode.
I do not recommend using an RS motor for a critical, high load (high current) application such as the drivetrain.
Unread 10-02-2015, 13:15
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
Rookie Year: 2011
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Remember FP motors? Some teams used them in their drivetrains.
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 11-02-2015, 09:05
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
I believe the 775 has a bad reputation because many teams block the air input vents. This is largely because many of the gearboxes (banebots and AndyMark CIM-Sim) cover the input air vents and the motors overheat. One year we used the banebots gearbox and ultimately machined channels in the gearbox mounting face (look at the VersaPlanetary mounting plates) and that made a HUGE difference in the temperature of the 775 motors.
If you do use the 775 in your drivetrain (or anywhere else) absolutely make sure it is well ventilated. If you use the CIM-Sim at least drill some holes in the plate where the motor mounts to allow air to enter the input vents.
That said, the drivetrain is arguably the most important subsystem on your robot. Do a risk/reward analysis before moving from the miniCIM to the 775. Is there anyplace else you can save a few pounds?
Unread 11-02-2015, 09:26
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Winner winner, chicken dinner.
As a team that has successfully used the 775 in numerous applications with no failures (arm motors in 2011, stalled to hold arm position; shooter motors in 2012; climbing motor in 2013; intake motors in 2014) ventilation in continuous-use applications is strongly recommended. Make sure you're operating in the higher-half of the RPM range too, they tend to heat up otherwise.
IMO 775s would do fine in a drive-train that was driven at high speeds and would not do well in a drive-train that was mostly driven at low-throttle values. This is entirely based on the heating/efficiency of the motor - look at the motor curve and seriously consider where on that curve the motor will generally be operating. For this game, with lots of low-speeds and fine-positioning moves, it might not be a well-suited motor.
Also bear in mind that drive-train weight is generally low in the robot. Removing mass from components higher off of the ground than the drive-train will have a larger positive impact on the robots overall dynamic performance.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 11-02-2015, 09:52
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
775's have another black mark against them - that's the shorting issue teams had when they were first released. There's nothing more frustrating than having to repeatedly change out 775 motors during inspection because of internal debris causing shorts that ground your PD board.
We haven't used them since that year. Fool me once, etc. Many other teams have used them since then.
We used 550's very successfully on our drivetrain in 2008. That year, however, you were generally trying to drive at full speed. This year, there is a lot of slower-motion movement aligning, adjusting, and setting things down. That means that any low mass air-cooled motor is not going to be terribly happy. Active cooling on the motor (a fan) will help tremendously.
Unread 11-02-2015, 12:00
protoserge's Avatar
This is absolutely a huge issue. Case shorting is directly attributed to overheating the enamel on the commutator shaft. The BaneBot transmissions that blocked the air intake vent were the leading cause of failure when this issue was present in 2010-2012. Many of the newer transmissions I've seen have this air intake slot already machined into the transmission.
If you have a transmission without an air intake slot, it would be best to mill a slot for air intake.
  #15   Spotlight this post!
Unread 10-02-2015, 12:47
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
I think I remember hearing stories from you guys either in 2011 or 2012 about burning out the 775's on your drives those years.
Also, even with no defense I would not recommend using 775's on drive. Even though they are not going to be stalled pushing, it still takes alot of torque to accelerate a robot. During acceleration, it is sitting at a higher current load generating more heat. Especially if you have a robot that weighs close to 200 lbs loaded. With high traction wheels and a heavy robot, I think it would burn out even trying to accelerate, unless you also had CIMs on the same gearbox to help with the acceleration.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
