Thread Tools |
Rating:
Display Modes |
Re: RS775 In Drivetrain?
You gave yourself the best advice in this whole thread. Test it out for yourself in your application. That's really the only way to know.
My only personal experience w/ the RS775's is we used them on our shooter head drive wheel to accelerate & shoot those foam basketballs a few years back (one on each side, 1 running forward / 1 reverse on a large wheel in CAN w/ Black Jaguars), and they sometimes made some pretty flames mid- match. YES real fire, not just the magic smoke (we replaced quite a few that season I remember), until we made the mounts huge Alum. heatsinks to bleed off enough heat from the motors (so, in the end there was no real wt. savings in the end result, over using CIMS or mini-Cims).
And they were not constantly reversing direction often as in a drivetrain (or at all), just momentarily stalling of the wheel, as the fed balls made contact, and they were running very hot. Cooling them is very necessary if you do choose that route....Might also want to keep a fire extinguisher really handy while using them to drive weight this year, if that ends up your final choice. Just a suggestion. They sure made those basketballs fly though, w/ real good backspin too! That Mid-Field Beam Though...Ugggh! Cracked every weld on that 2 sided bot repeatedly. |
Honestly, it may work. I wouldn't risk it because any match you don't drive is a match you don't score. At all.
If there's an auto problem and you drive into a wall you could be dead for a match and have to replace drive motors. Even stopping or accelerating abruptly could cause problems. Stick to CIMs. It will be cheaper and less time consuming to save weight somewhere else then it will be to put 775s in drive then troubleshoot them. Even if it would work properly it's not worth the risk IMHO. |
