Go to Post In my opinion, leaders do not need to be picked. They naturally emerge as time goes on and as more opportunities are presented to them. - Alex Golec [more]
Thread Tools Rating: Thread Rating: 6 votes, 4.50 average. Display Modes
Unread 10-02-2015, 13:53
cusack80 cusack80 is offline
None #5256
cusack80 is an unknown quantity at this point
Window Motor/Snowblower and 12v only one way
We have tried both motors both ways. We are running off a talon. It works great one way and stutters the other direction. When we check voltage 12v working going up and hardly anything going down. When we reverse our pos and neg on motor the problem reverses. If we hardwire (mentor does this) to battery it runs both directions fine. We go back and wire it back to the talon problem reappears and one direction works flawless other direction stutters like it is not getting power....this is for our elevator mechanism. We have tried switching PWM cable, window motor and snow blower motor and tried victor or talon and problem replicates. Any ideas?
Unread 10-02-2015, 13:59
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Window Motor/Snowblower and 12v only one way
Two thoughts...
First, have you removed the locking pin in the window motor? (R19 part C)
Do you need variable seeps control? Have you tried using a spike relay instead? This would act the same as hooking it up straight to a batterychoking you full speed in both directions. (Table 4-4 under R42)
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 10-02-2015, 14:05
None #5256
Will check the spike relay tonight as we have one from last year...
Unread 10-02-2015, 14:09
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
The thing that seems common to all of these scenarios is the signal coming from the 'RIO.
It is unlikely that you have a bad port on the hardware, but it's an easy thing to check.
What seems more likely is that you've declared an unusual motor controller class (or perhaps a servo) which has a different range of pulse widths than the controllers.
What language and motor controller class are you using to program?
Unread 10-02-2015, 15:08
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I'm going to guess that you're using a pair of buttons to control the motor. You probably have an if/then for each button, where the first chooses either forward or off, and the second chooses either reverse or off. If you press the second button, you get reverse power to the motor. But if you press the first button, you get forward power just for an instant before the second if/then shuts it off again.
If that's what your code is doing, you need to fix it to turn off the motor only if neither button is pressed.
Unread 11-02-2015, 06:29
None #5256
Update to issue: seems to be related to snowblower/window motors and not cims.....
FYI, changed code so upper motor could successfully operate in both directions. Motor operated smoothly. Then hooked snowblower motor to upper motor talon, problem persists with that motor. So, still the same problem, but with different (otherwise successful) talon, pwm port, pwm wire, code, and 12v supply to talon...
Dakota plans to research how to code the relay in case that ultimately ends up being a simpler workaround. Changes to wiring were undone before putting away bot.
Thanks,
Unread 11-02-2015, 08:16
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
cusak,
It could be that the one direction has significant current demands. As such, the breaker may be tripping open. Do you hear a clicking sound when the motor stops? The motor controller may also be going into over current protect. Do you notice any LED behavior on the controller that is different than the other direction?
Al
WB9UVJ
www.wildstang.org
________________________
Unread 11-02-2015, 08:18
None #5256
Hi, the light on the PDB board are blinking orange? You definitely feel the motor running smooth when you put your hand on it going one direction and then the other direction you can feel where the motor almost has a pulsating current where the loop starts and then cuts out...
Unread 11-02-2015, 08:36
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
PDP blinking yellow means you have or had at one time a low battery.
If you don't clear the yellow sticky fault though, it stays around forever.
Clear it by using the roboRIO WebDash, clicking on PDP and clicking the Self-Test rapidly in succession.
Unread 11-02-2015, 09:11
None #5256
We will check the speed controller to check signal light....Not sure why the current would want to be different one way than another...
Unread 11-02-2015, 09:18
Software Architect
You said this is for an elevator. Unless you have an effective counterweight, gravity makes it easier to go down than to go up.
Pay attention not only to the speed controller LEDs but to the Power Distribution Panel too. You'll hear a definite click if the circuit breaker trips.
Unread 11-02-2015, 09:34
None #5256
Thanks Alan,
The weird thing is going hard wired to battery both work fine either direction. If we switch neg and pos we can manipulate if the problem occurs going up or going down...It will work one way or another, but not both. I can get it to go up fine, switch power leads get it to go down, but it will not act right both directions.
