Go to Post You are joining the greatest family in the world, FIRST, because we all strive to practice GP. - Ken Loyd [more]
Unread 10-02-2015, 16:47
sarah_storer's Avatar
sarah_storer sarah_storer is offline
Georgia Tech RoboJackets Outreach
AKA: Sarah Storer
FRC #5332 (Toaster Tech)
Rookie Year: 2013
sarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to behold
Setting a switch On The Dashboard Help
We want to be able to set a switch on the dashboard so we could switch between autonomous can someone help me with this? Any help will be gratefull. I will be waiting.
TEAM 3753 BULAH BOTS ALUMNI
2012-2015: Code, pneumatics, and electrical for BULAH BOTS Team 3753
2013: Bayou Regional 1st seed alliance captain and regional winners (With 118 and 4589)
2014, 2015: Bayou Regional semi-finalist
2016-?: Mentor for TOASTER TECH Team 5332
2016: Columbus District 3rd seed alliance captain, semi-finalist; Kennesaw District 3rd seed alliance 1st pick, semi-finalist; Peachtree District State Championship 4th seed alliance captain, quarter-finalist, Industrial Design Award, World Championship qualification
Unread 11-02-2015, 02:43
Optimism's Avatar
Optimism Optimism is offline
AKA: Calvin Ly
FRC #2468 (Team Appreciate)
Rookie Year: 2012
Optimism is an unknown quantity at this point
Re: Setting a switch On The Dashboard Help
The simplest method is to use a combo box on the front panel (which would allow for multiple autonomous selections and an easy/interaction drop down menu), right click on "Edit Items", and then input your items/values. Then in the block diagram, wire the combo box into a smart dashboard write value vi and name the variable (all of this in Loop 1 of the dashboard project). In your autonomous vi, read the value of the variable in using the smart dashboard read value (make sure to use the same name of the variable) and then wire that into a case structure and program your autonomous actions in the case structure.
