How do you get interrupt when digital input is set
Is there code showing how to get a interrupt when say a limit switch is hit?
I see the public abstract class InterruptHandlerFunction<T> is there example code of how to implement this for the requestInterrupts off DigitalInputs? I'm having trouble with how to define the polymorphism of the function properly. Thanks |
Re: How do you get interrupt when digital input is set
This is how I used interrupt handlers in a gyro driver. The really wierd part about it is that the interruptFired() method is package private, so any class that uses it needs to be in the edu.wpi.first.wpilibj package. I think this was an oversight on the part of the authors of WPILib.
Code:
DigitalInput interrupt = new DigitalInput(0);
// Register an interrupt handler
interrupt.requestInterrupts(new InterruptHandlerFunction<Object>() {
@Override
public void interruptFired(int interruptAssertedMask, Object param) {
// Do stuff
// Listen for a falling edge
interrupt.setUpSourceEdge(false, true);
// Enable digital interrupt pin
interrupt.enableInterrupts();
Thanks, actually the private part is what was reallly killing me, I just could not get the thing to be happy I had the same code...
testinput =new DigitalInput(0); testinput.requestInterrupts(new InterruptHandlerFunction<Object>() { @Override public void interruptFired(int interruptAssertedMask, Object param) { } }); I just couldn't get it to like the interruptFired no matter how I set it up...the base class having an error explains it though Thanks |
