Go to Post Doughnuts would probably be a pretty good alternative to churros. However, that could be open to debate. - Calvin Hartley [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 02-11-2015, 09:55 AM
Mschmeh144's Avatar
Mschmeh144 Mschmeh144 is offline
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Rookie Year: 2014
Mschmeh144 is an unknown quantity at this point
Talon sr, or SRX?
What type of talon are you using this season?
Personally, we are using at least six talon SRX controllers on our bot, I haven't counted them, but this may be a problem because we don't have enough spares. So, which talon would be more reliable to use, the SR or the SRX?
Also, is it possible to mix the two of them for use at the same time, not during competition, but on our test rig? Currently we have a testebed aptly named "ghettobot" which has four talon SR controllers but also has the option to use the two spare SRX controllers we have. Currently we just swap them using a few connectors when we need to work with the SRX, but would it be possible to avoid this and just leave them connected but disabled, as they are hidden under a platform attached to the robot and are hard to get to.
Thanks, any help would be appreciated
Unread 02-11-2015, 10:03 AM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Talon sr, or SRX?
There's no problem in having a speed controller present and powered but with no motor connected.
Do not, under any circumstances, connect the outputs of two speed controllers together.
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
The SRs have proved to be very reliable so it is a tall bar for the SRXs to beat. The SRXs have more electronics in them, if you are not using canbus the Victor SPs might be a better choice. In either case neither have been out long enough to have fully established a reliability record comparable to the SRs.
While it is best not to mix controllers in a subsystem, I would hesitate to do it at a completion if that is was the only option.
If you don't know what you should hook up then you should read a data sheet
Unread 02-11-2015, 10:12 AM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We're late adopters. Six of the SR on our robot.
Unread 02-11-2015, 10:33 AM
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
Rookie Year: 2012
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
We're using five SRX's. The SR's were pretty good, but the SRX's blow them out of the water.
Unread 02-11-2015, 10:36 AM
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
How so? Assume you are using PWM & no limit switches so you are comparing apples to apples.
Now if you are comparing Talon SRXs to Jag...
Unread 02-11-2015, 01:09 PM
Mschmeh144's Avatar
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Rookie Year: 2014
the talon srx has a closed casing, but so does the sr. the thing I don't like about the talon srx is the wires that come pre-attached. if you cut them or strip them you cannot make a mistake, or you've got yourself a useless talon. even the CAN wires come preattached, in the model that has them at least, im not sure if there is a PWM model.
also, its perfectly okay to have them plugged into the pdp and running on robot startup, but not connected to the motors?
Unread 02-11-2015, 01:11 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Same here.
Good thing. We only have five motors (3 H-drive, 2 on lift). The sixth has leads with Anderson connectors on the end. We started laying out the board before we knew what we needed, and while we took the PCB off, we left the unused talons and spikes as spares. (We're using the spikes for lighting).
Unread 02-11-2015, 01:13 PM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Sure. It's a custom circuit consisting of a very high-value resistor.
Unread 02-11-2015, 01:15 PM
Pretzel Pretzel is offline
Ex-Driver
AKA: Tyler
FRC #1619 (Up-A-Creek Robotics)
Rookie Year: 2012
Pretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to behold
We made a large investment in 24 Talon SRX's, as our design requires twelve and we're building a practice bot on top of the competition ones. So far, we've been VERY happy with them compared to the Jags we used previously.
It's not done until it's overdone!
Unread 02-11-2015, 02:04 PM
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
FRC #0973 (Greybots)
Rookie Year: 2012
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
There's quite a bit of wire on the SRX controller, it would take a large quantity of screw-ups to shorten the wire to the point where the SRX becomes unusable. If anything, the integrated wires are a plus because the electronics are physically isolated from the outside environment.
(2015-?): 973
(2012-2015): 955
Unread 02-11-2015, 02:16 PM
Mschmeh144's Avatar
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Rookie Year: 2014
This is true. But, accidents do happen. Especially with our testebed, which unexperienced members use like a toy.
Unread 02-11-2015, 02:21 PM
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
For critical components, we're also late adopters. 8 SR's on our bot (1 spare).
Unread 02-11-2015, 02:25 PM
Mschmeh144's Avatar
Impatient maniac
AKA: Matthew
FRC #0144 (R.O.C.K)
Team Role: Driver
Rookie Year: 2014
We found it easy to just buy a ton of them too, but we didn't buy enough to have a spare for every one that we actually use. I am impressed with their closed casing, and the way they are generally built allows them to be packed tightly into small spaces. Otherwise, we would be using talon SR controllers instead. They are definitley a improvement over the Jags, but only time will tell how much of a improvement.
  #15   Spotlight this post!
Unread 02-11-2015, 02:33 PM
AKA: Ethan
Rookie Year: 2012
Talon SRX's use CAN, so we can get real-time data on the WebDashboard; they have passive heatsinking; they are microcontrollers, so the PID loop that controls them is offloaded; and it's almost impossible to get metal shavings in them.
Also CAN wiring is a lot better than PWM wiring.
