Go to Post Call it confidence, call it ego, call it what you want, but the fact of the matter is you need to be humble or someone will humble you. - Dan Richardson [more]
Unread 11-02-2015, 13:35
joliet cyborgs joliet cyborgs is offline
FRC #4241
joliet cyborgs is an unknown quantity at this point
Swerve Drive Help
Our team is trying to implement swerve drive for the first time and we are having problems with oscillation on our steer motors and the steer motors not getting to the setpoints properly. The setpoints seem to be calculating just fine however. We are using MA3 absolute analog encoders and CANTalon motor controllers for all 8 of our motors. Our encoders are coupled directly to the shafts of the steer motors.
Here is our code for reference. It is a stripped down and simplified version of team 16 BombSquad's code from last year:
https://github.com/JTHSConnelly/Cyborgs2015
Unread 11-02-2015, 18:06
FRC #4241
Re: Swerve Drive Help
Nevermind! We fixed it. It was all the build team's fault.
Unread 11-02-2015, 19:10
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Can you explain what the root cause was, and how you figured it out? Might help another team.
Also I was curious...
Unread 11-02-2015, 19:54
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Rookie Year: 2010
Jefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant future
I'll let them explain it, but, given their code base, I was happy to hear it wasn't code related.
Unread 11-02-2015, 21:05
FRC #4241
Thanks again Jefferson! So helpful! The leads to the steer motors were reversed. When we switched the leads or instead just put in a negative P value in our PID for the code, it worked. Not sure why it caused the motors to behave in the way they did. Someone more technically versed than I can probably explain it better.
