Go to Post No such thing as asking too much. There is such a thing as asking too fast, but not too much. - EricH [more]
Unread 02-11-2015, 04:00 PM
choas500 choas500 is offline
FRC #4640
choas500 is an unknown quantity at this point
need help programming arms with extra motor and talon
please help us
this is our code so far..
package org.usfirst.frc.team4640.robot;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
public class Robot extends SampleRobot {
RobotDrive myRobot; // class that handles basic drive operations
Joystick leftStick; // set to ID 1 in DriverStation
Joystick rightStick; // set to ID 2 in DriverStation
CameraServer server;
public Robot() {
myRobot = new RobotDrive(0, 1);
myRobot.setExpiration(0.1);
leftStick = new Joystick(0);
rightStick = new Joystick(1);
server = CameraServer.getInstance();
server.setQuality(50);
//the camera name (ex "cam0") can be found through the roborio web interface
server.startAutomaticCapture("cam0");
* Runs the motors with tank steering.
public void operatorControl() {
myRobot.setSafetyEnabled(true);
while (isOperatorControl() && isEnabled()) {
myRobot.tankDrive(leftStick, rightStick);
Timer.delay(0.005); // wait for a motor update time
Unread 02-11-2015, 04:55 PM
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Rookie Year: 2010
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Re: need help programming arms with extra motor and talon
I reformatted using code tags -- use these in the future. It makes code easily readable.
Code:
public Robot() {
I recommend you look at existing code already published, GitHub has lots of resources that you can look at. I have no experience with this code but with Iterative and CommandBased I do.
Talons are as simple as
Code:
Talon t = new Talon(0); // PWM is plugged into PWM port 0
To move your Talon, do
Code:
t.set(1); // sets full speed forward
t.set(-1); // sets full speed backwards
t.set(0); // stops the motor
To control it with a button:
Code:
Joystick driverStick = new Joystick(0);
Button driverButton1 = new JoystickButton(driverStick, 1);
if(driverButton1.get()) { // if pressed
t.set(1);
} else {
t.set(0);
These are very rudimentary and crude code pastes but hopefully you get the idea.
