Go to Post I wouldn't want to face THAT bad boy in competition... - Iain McLeod [more]
Unread 12-02-2015, 00:48
2508electronics 2508electronics is offline
The One Man Electrical Team
FRC #2508 (Armada Robotics)
Team Role: Electrical
Rookie Year: 2013
2508electronics is an unknown quantity at this point
2508's electronics board
This is only half of our electronics board since I am putting the power related stuff on one side of the robot and the signal related stuff on the other side (mostly). To stack wires, I used the 3M double sided tape that has the red lining and stacked pairs of wires with that in the middle.https://www.dropbox.com/s/pzz83g7mj4..._0028.jpg?dl=0
Unread 12-02-2015, 08:59
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: 2508's electronics board
Originally Posted by 2015 Game Manual, R33
The VRM supplying power to the Wireless Bridge per R32 must be connected to the designated supply terminals at the end of the PDP, and not the main WAGO connectors along the sides of the PDP as shown in Figure 4-5. With the exception of a single Cross the Road Electronics Pneumatics Control Module (PCM, P/N: am-2858), no other electrical load may be connected to these PDP terminals.
While the rules don't require it, the guidance seems to be that the pneumatics control module should be connected to one of the PDP terminals at the end of the board, not one of the WAGO connectors. Also, while I can't make out the breaker size in the image, the PCM must have a 20A breaker or fuse per R37.
I suppose that you realize that the RoboRIO and VRM need power (from the appropriate terminals at the top end of the PDP) and that you still have to connect motor wires.
It certainly has a clean, roomy look; apart from the small breakers' WAGOs, everything has plenty of access room.
We've done two-sided (and even multi-part) control boards in previous years, but we found that having a single board that you can see "all at once" is less prone to wiring errors and much easier to trouble-shoot.
It looks OK, but you should also make sure that the compressor wire is not in contact with the compressor. Wires increase in resistance as they get warmer, so you want to keep it a bit clear of the compressor.
Unread 12-02-2015, 09:11
MrRoboSteve MrRoboSteve is online now
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Lots to like here. A couple things for you to consider:
1. I'm not a fan of putting the compressor on the electronics board. The terminals on the speed controllers tend to vibrate loose and that's a big source of vibration.
2. Use some cable tie bases to fasten down your power wires, rather than the tape. Use a cable tie near each speed controller to make a bundle of the two input wires. This makes them move less at the speed controller. The bases are available at Home Depot.
3. Are you planning on putting fans on your Talons?
4. You're using polycarbonate (Lexan) and not acrylic for the board, right?
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
