Drive Train Curves Only While Backing Up
Hello,
For some reason our drive train is curving to the right only when we backup. When we use the joysticks, it does not curve. When we set the talon manually (Talon.set(-1)), it curves to the right pretty severely. We're using a 6-wheel drive train (3 on each side) with a mini toughbox. Our motors are 4 KoP CIM motors and we're using 4 talons for our motor controllers. We're splitting the PWM cable so we're only using two PWM cables to access the 4 talons. We're kind of unsure what this could be so I was wondering if anyone had an issue like this before or what your ideas might be as to what's causing it. Thanks! |
Re: Drive Train Curves Only While Backing Up
The lights are a solid green when backing up. This is due to the fact that our motors are sort of hooked up backwards -- from the way it was explained to me we would have to swap the negative and the positive wires to fix it in hardware (which is supposedly a big no-no) so I've been compensating for it in programming. Is this what most teams do? |
I suspect the call to the tank drive method or the open constructor would include similar parameters to invert the motor outputs. Last edited by BitTwiddler : 12-02-2015 at 13:49. |
Did you calibrate the speed controllers?
No, we did not -- I didn't know that this is possible. How would I go about doing this?
http://www.crosstheroadelectronics.c...Manual_1_1.pdf On page 7 are the calibration instructions. |
It's the first thing I would do....it doesn't cost anything, but time.
#10
We swapped the PWM cables in the RoboRIO (port 0's cables are now in 1 and port 1's cables are now in 0) and now, when reversing, we reverse while curving in the opposite direction. We hooked the output of them up to an oscilloscope and it is showing that one port's PWM is getting more signal than the other although in the code I am giving them the same values. Any ideas? For example, if I do RobotDrive.tankDrive(-0.5, -0.5) it is producing the PWM similar to RobotDrive.tankDrive(-0.6, -0.5). |
#11
Are you declaring both motor controllers to be of the same class (e.g. not one Talon and one Jaguar)?
See the second paragraph in the white area of: http://wpilib.screenstepslive.com/s/...ns-and-jaguars |
#12
That pretty much rules out any mechanical causes.
#13
Another thing to try is program for ports 1&2 to see if it related to a specific port since the issues are common to port 0 Aloha! |
#14
Thanks for all of the replies so far everyone.
I'm not there testing but have someone else testing. I'm going to be recalibrating them (and consequently posting here with my findings) sometime around 3 PM EST today. Maybe I'm interpreting the oscilloscope wrong -- here are the images I received. Linking to rather than embedding the pictures because they're massive. Oscilloscope Reading #1 Oscilloscope Reading #2 The readings are from the PWM signals with the ports swapped running the very basic code below I wrote to confirm it wasn't a programming issue. As for my code testing this, I literally just created a new IterativeRobot I just did: Code:
RobotInit() {
Talon t = new Talon(0);
Talon t2 = new Talon(1);
RobotDrive rDrive = new RobotDrive(t, t2);
TeleopPeriodic() {
rDrive.tankDrive(-1, -1);
#15
I concur. What do the outputs of 3, 4, and so forth look like? Whichever one disagrees with the others should be reserved for standalone (one controller) functions, not the drive train.
