Re: Drive Train Curves Only While Backing Up
I'm not sure I understand what you mean, sorry. Are you referring to the individual motors themselves or do you mean the PWM ports?
These pulse widths are being determined by the 'RIO, not the controllers.
We had exactly the same problem earlier in the season and it turned out to be the joysticks, so make sure it's not those. You can do this by watching the joystick outputs on the Dashboard. If that is the problem, you can easily fix it by putting in a bigger deadband.
Are you saying that the direction of curving is following the code, not the hardware?
if so, you'll have to get some help from a programmer....and I suggest you post images or listings of your code so they can see what you have done. |
