Go to Post Polycord. It was used in all sorts of ball systems in 2009, and on some of the 2007 claws. It's not too hard to fuse together by hand with some heat and patience. - AustinSchuh [more]
Unread 12-02-2015, 11:31
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Team Role: Leadership
Rookie Year: 2012
Toa Circuit is an unknown quantity at this point
Logging error to driver station
We are using the RS-232 port on the roboRIO, so we can't use console out. I'm pretty sure I saw somewhere there's a way to put errors in the error log in the driver station (such as the ones seen at http://wpilib.screenstepslive.com/s/...rors-warnings).
We will be using this just for logging exceptions that are encountered via a try-catch; not like a constant stream of output data.
I'm struggling to find the class/method to do it. Does anyone know what it is?
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 12-02-2015, 11:39
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Re: Logging error to driver station
DriverStation.reportError() is your friend.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 15-02-2015, 22:05
shindigo shindigo is offline
AKA: Mike Parker
FRC #0102
shindigo is an unknown quantity at this point
Unfortunately, we've found that reporterror does not give the stack trace to the error but to the line that reports the error Putting ex.printStackTrace() in our exception handlers is necessary.
Unread 17-02-2015, 11:48
MatthewC529 MatthewC529 is offline
Lcom/mattc/halp;
AKA: Matthew
FRC #1554 (Oceanside Sailors)
Rookie Year: 2013
MatthewC529 is on a distinguished road
We wanted the same thing, so after some digging around I have this code:
Code:
      public static final void writeToDS(String message) {
		final HALControlWord controlWord = FRCNetworkCommunicationsLibrary.HALGetControlWord();
		if (controlWord.getDSAttached()) {
			FRCNetworkCommunicationsLibrary.HALSetErrorData(message);
    public static final void exceptionToDS(Throwable t) {
		final StackTraceElement[] stackTrace = t.getStackTrace();
		final StringBuilder message = new StringBuilder();
		final String separator = "===\n";
		final Throwable cause = t.getCause();
		message.append("Exception of type ").append(t.getClass().getName()).append('\n');
		message.append("Message: ").append(t.getMessage()).append('\n');
		message.append(separator);
		message.append("   ").append(stackTrace[0]).append('\n');
		for (int i = 1; i < stackTrace.length; i++) {
			message.append(" \t").append(stackTrace[i]).append('\n');
		if (cause != null) {
			final StackTraceElement[] causeTrace = cause.getStackTrace();
			message.append(" \t\t").append("Caused by ").append(cause.getClass().getName()).append('\n');
			message.append(" \t\t").append("Because: ").append(cause.getMessage()).append('\n');
			message.append(" \t\t   ").append(causeTrace[0]).append('\n');
			message.append(" \t\t \t").append(causeTrace[2]).append('\n');
			message.append(" \t\t \t").append(causeTrace[3]);
		writeToDS(message.toString());
This will send messages directly to the DriverStation LCD.
This can either write to the DS or log a Stack Trace to the DS. If there is a cause it goes one-level deep and logs the cause as well.
It does make use of StringBuilder but this is entirely feasible just appending Strings.
StringBuilder was used just to maintain memory and speed.
Team 1554 -- Oceanside Sailors
  • 2013-2014 - Lead/Sole Programmer
  • 2014-2015 - Lead Programmer, President
  • 2015-? - Team 1554 Mentor
Independent Public Projects
Developer at Legend Zero LLC.
Java/C++ Programmer
