| Thread Tools |
Rating:
Display Modes |
Design and engineering mgmt rules
The various engineering industries seem to each have their own set of rules of thumb, collected from great minds and scraped from millenia of collective experience. Sometimes tongue-in-cheek, these are all about overcoming unique technical and nontechnical challenges. Occasionally they veer into the specific, but viewed as a whole, they can be seen as a set of philosophies for developing systems that consistently produce working designs.
Conveniently, building a high-functioning FRC team is also about developing systems that consistently produce working designs. As such, many of these rules are applicable to FRC. Kelly Johnson, famed Lockheed systems and aeronautical engineer, developed his 14 Rules of management which he used to run Skunk Works for decades:
In particle accelerator design, there's the Gospel According to Bill Brobeck. I'll repeat the entire thing here because it's a rare find out in the wild:
In spacecraft design, there's Akin's Laws, now infamous because they were so widely circulated in the early days of the internet:
What other lists of rules are out there? |
Re: Design and engineering mgmt rules
Three Rules of Engineering:
1) Always us the right tool for the job 2) The right tool is always a hammer 3) Anything can be a hammer |
Mystery Solved!
For years, I've wondered why spacecraft occasionally disintegrate, but I've never head of a particle accelerator disintegration. Now I know why.
BTW, what sort of wrench do you recommend to hammer in a masonry screw? |
Adapting some old ASW (antisubmarine warfare) axioms into robotics terms:
Re: Mystery Solved!
https://edms.cern.ch/file/973073/1/R...at_LHC__2_.pdf |
If all you are is a nail, every hammer looks like a problem.
I would suggest a 30 oz Freshman adjuster.
Ooh, ooh. I want to play.
FIRST rules and lessons learned over the past 5 years (sometimes the hard way): 1) Setscrews are not power transmission devices. They are evil. They fail when you need them, and damage parts when used correctly. 2) Never set down a tool. It either goes in your tool pouch or the toolbox. 3) No one leaves until the shop is clean. I am not your mommy or daddy and I shouldn't have to stay late to clean up your messes. 4.a) Planning for wiring and electronics is one of the most important design tasks on the robot. 4.b) Neatness and quality of wiring is a strong indicator of a quality robot. 5) The proper sized clearance hole for a fastener is the size of the fastener. If you need to drill larger holes to make something fit, you messed up somewhere. 6) On your prototypes and practice bot, match drill everything. On your competition bot, match drill nothing. 7) CAD is a tool, not an end product. Model what you need to, and nothing more. 8) A slide show is not a video. 9.a) Matches are won and lost in the pit. 9.b) Bring a spare for every COTS actuator and sensor on your robot. 9.c) The most important job on the pit crew is Ambassador. They keep others from distracting the hands-on workers. 10) Neatness counts in your shop, in your pit, in your storeroom. If you can't find something quickly, you might as well not even have it. 11.a) During build season, time is your most valuable resource. If a student is not working, they are not contributing. If a student is distracting others, they are actively hurting the team. 11.b) Mentors cannot effectively mentor more than 4 students at once. 12) Summer is for development projects (including drivetrain). Fall is for new student skills development and robot build practice. Build season is for execution. 13) If there's no video, it didn't happen. 14.a) Planning is easy. Execution is hard. 14.b) On CD, don't talk about what you plan to do. Demonstrate what you have done. 15) Don't spend time making something if you can buy it. (unless it saves you a ton of money on your BOM) 16.a) Use COTs parts whenever possible. They don't count against your withholding allowance. 16.b) Pre-purchase COTs drivetrain parts. FIRST does not enforce vendor part availability rules. FIRST vendors know this, and do not keep adequate stock. 17) It's even more important to keep Gracious Professionalism in mind when you are doing good than when you are doing bad. 18) All threaded fasteners should either have a locknut or loctite. 19) Loctite destroys lexan. 20) Use flush cutters to trim off wire-ties, NOT diagonal cutters. 21) On the control panel, use switches for state functions (arm in/arm out) and buttons to initiate actions (shoot). 22) Drivers and operators should never need to take their eyes off the robot. Driver's station displays are for troubleshooting, not operations. 23) Do not overwrite old code. Always keep previous versions, so you can go back to something that used to work. 24) No matter how many times your pit crew and drivers say they don't need one, they both need pre-match checklists to be sure the robot is configured for a match. 25) Use hex shafts rather than round shafts with keys. 26) Don't ask your match partners what they can do. Ask your scouts what they have done. Last edited by ToddF : 02-12-2015 at 02:11 PM. |
#10
I agree with most of ToddF's rules, and most of the ones I don't are matters of taste. There is one, however that I shall rebut:
But no, don't post them on Robot Showcase! Last edited by GeeTwo : 02-12-2015 at 03:49 PM. |
#11
I have yet to see suppliers run out of round bore bearings or half inch, keyed round driveshaft during build-season
#12
My team's favorite for jobs like that is the left-handed French metric adjustable open-ended magnetic reverse-ratcheting box wrench.
#13
1. Testing each motor/motion individually 2. Charging pneumatics 3. Swapping to a fully charged battery 4. Ensuring the battery is plugged/strapped in 5. Checking driver station laptop battery charge 6. Checking camera/critical sensor functions |
