Go to Post you must understand when wearing that FIRST Volunteer shirt, you personally & directly represent FIRST, and you do the best job for FIRST as an organization, that you can in performing that job....Period. - cglrcng [more]
Unread 12-02-2015, 13:09
jagow100's Avatar
jagow100 jagow100 is offline
FRC #3539 (Byting Bulldogs)
Rookie Year: 2013
jagow100 is an unknown quantity at this point
Multithreading in Java
Me and my team all understand multithreading, but we're all confused on how you would attempt multithreading with this control system. We wish to put the camera on a separate thread so it doesn't slow down the rest of the code. We have the camera code set up as well but since it has to wait for the camera to update its picture, it has a huge amount of input lag from the controller. Any help would be appreciated.
- 3539 Programming Team
Unread 12-02-2015, 13:10
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: Multithreading in Java
We just created a thread and started it in robotinit() for vision processing.
Unread 12-02-2015, 13:29
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Here's what I'd do.
1. Make a new type -- say ImageAnalyzer -- that is a Runnable. This type will do the image analysis.
2. Create another new type ImageAnalyzerResult that has properties:
estimatedToteDistance
estimatedToteAngle
This type is used to return the results of the analysis to your main robot logic.
3. The ImageAnalyzer.run() method would have a loop that would repeatedly run your image analysis, likely with some delay between runs to not completely eat a CPU.
Your image analysis code would look like this:
a. Acquire an image from the camera
b. Perform some analysis of the image to determine the robot's angle relative to the vision target on a tote.
c. Create a new ImageAnalyzerResult, and set the two properties to the calculated values from your image analysis. You want to make a new one of these each time you do your image analysis, so that you don't have synchronization issues with the analyzer and the code that uses the result.
4. Add a method to ImageAnalyzer named something like getResult() that returns the current ImageAnalyzerResult if you're seeing a tote, and null if not.
5. When your robot is starting, say:
(new Thread(new ImageAnalyzer())).start();
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 12-02-2015, 13:30
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
1. Creating a thread
http://www.tutorialspoint.com/java/j...ithreading.htm
The first example demonstrates creating a class type that creates a thread to do work in.
2. How to share information between thread and your main program flow
The next step is to take the results of the camera logic and save them to some member variables in the class type, so that the "main" thread in Robot can safely poll them out using sychronized accessors.
http://docs.oracle.com/javase/tutori.../syncmeth.html
Unread 12-02-2015, 13:39
jagow100's Avatar
Rookie Year: 2013
We got it working, thanks guys.
