Go to Post No really though, a robot game with rules similar to Risk. This would combine FIRST, Battlebots, and US Government... - Betty_Krocker [more]
Unread 02-12-2015, 03:27 PM
Hawk_Prime Hawk_Prime is offline
FRC #3229
Hawk_Prime is an unknown quantity at this point
Coding for a lifter?
Hi, I'm vincent from FRC team 3229, Hawktimus Prime. We just finished our drive program yesterday and now we need to work on the lift mechanism for our robot so we can pick up totes. The only code we have is one Java file called Robot.java in our project. Here's the code:
Code:
package org.usfirst.frc.team3229.robot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.RobotDrive.MotorType;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Timer;
 * This is a demo program showing how to use Mecanum control with the RobotDrive class.
public class Robot extends SampleRobot {
    RobotDrive robotDrive;
    Joystick stick;
    // Channels for the wheels
    final int frontLeftChannel	= 3;
    final int rearLeftChannel	= 4;
    final int frontRightChannel	= 2;
    final int rearRightChannel	= 1;
    final int elevator = 6;
    // The channel on the driver station that the joystick is connected to
    final int joystickChannel	= 0;
    public Robot() {
        robotDrive = new RobotDrive(frontLeftChannel, rearLeftChannel, frontRightChannel, rearRightChannel);
        robotDrive.setInvertedMotor(MotorType.kFrontLeft, true);	// invert the left side motors
    	robotDrive.setInvertedMotor(MotorType.kFrontRight, true);
        robotDrive.setExpiration(0.1);
       stick = new Joystick(joystickChannel);
     * Runs the motors with Mecanum drive.
    public void operatorControl() {
        robotDrive.setSafetyEnabled(true);
        while (isOperatorControl() && isEnabled()) {
        	// Use the joystick X axis for lateral movement, Y axis for forward movement, and Z axis for rotation.
        	// This sample does not use field-oriented drive, so the gyro input is set to zero.
            robotDrive.mecanumDrive_Cartesian(stick.getY(), stick.getX(), stick.getZ(), 0);
            Timer.delay(0.010);	// wait 5ms to avoid hogging CPU cycles
How would I go about just adding something where when you push a button on an xbox controller, a different motor goes? Thanks for the help!
Unread 02-12-2015, 03:29 PM
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: Coding for a lifter?
What kind of motor controller are you using? Talon, Victor, or Jaguar?
Unread 02-12-2015, 03:56 PM
cstelter cstelter is offline
Programming Mentor
AKA: Craig Stelter
FRC #3018 (Nordic Storm)
Rookie Year: 2012
cstelter will become famous soon enough
Ultimately I think you'll want to get to
Code:
    SpeedController elevatorMotor;
    private static final int LIFT_BUTTON=1; //or whatever button raises
    private static final int LOWER_BUTTON=4; //or whatever button lowers
    public Robot() {
        elevatorMotor=new Talon(elevator);
            if(stick.getRawButton(LIFT_BUTTON)) {
                 elevatorMotor.set(0.5);
            } else if(stick.getRawButton(LOWER_BUTTON)) {
                 elevatorMotor.set(-0.5);
            } else {
                 elevatorMotor.set(0);
but to get there you need some variable representing a SpeedController such as I've shown as elevatorMotor. I showed the code if you use a Talon. If you use something else as Matt was asking about, that line would be different. If you need to call more than just the basic SpeedController interface on you Talon/Jaguar/TalonSRX/etc, you can make the line be
Code:
Talon elevatorMotor=new Talon(elevator);
Then if there is a Talon specific function that is not on the SpeedController interface, you can still call that too. Just trying to keep it simple for you.
I've not used xbox class so I don't know if getRawButton is best way to get buttons or not, or if mappings exist avoiding need for LIFT_BUTTON/LOWER_BUTTON, but using local names with explicit names for lift and lower help keep your code more understandable.
Unread 02-12-2015, 03:58 PM
FRC #3229
Thank you!
