Go to Post I believe in the rookie teams. - Arefin Bari [more]
Unread 02-12-2015, 07:41 PM
calvinred calvinred is offline
None #5340
calvinred is an unknown quantity at this point
Motor Speed Definition Not Working
We have defined a motor speed for our talons controlling our lift motors (it is set to 1.0). How it is supposed to work is that when we press a button on our joystick, the motors will go at the speed we tell it too, the problem being that it doesn't. It gives a speed closer to .3 or .4. However, when we hook it up to a battery alone it goes at a speed of 1.0, or when we mess with our wiring so our drivetrain joysticks control those motors (this also puts the motors at 1.0). What could be causing this? Has anyone else dealt with this?
Unread 02-12-2015, 09:51 PM
Oromus's Avatar
Oromus Oromus is offline
Lead Programmer, Community Liason
AKA: Ryan
FRC #1902 (Exploding Bacon)
Rookie Year: 2013
Oromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to behold
Re: Motor Speed Definition Not Working
Could you post your code for detecting if the button is pressed, setting the motor's speed, and where you are defining your motors?
Unread 02-12-2015, 09:57 PM
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Also be sure that you are declaring the correct model of speed controller; jaguars have a different PWM range than Talons and Victors.
Unread 02-12-2015, 10:26 PM
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Rookie Year: 2010
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Sounds odd. Post your code here using code tags.
Code:
code goes here
Unread 02-13-2015, 09:38 AM
None #5340
Alright turns out it was something completely different. Thanks for the replies!
