Go to Post You can lay out all the disclaimers that you want, but the bottom line is you are representing your team. - Karthik [more]
Unread 12-02-2015, 19:43
jmb888 jmb888 is offline
AKA: Justin Beekman
FRC #0280 (TnT)
Rookie Year: 2015
jmb888 is an unknown quantity at this point
Camera IP Keeps Switching
Our robot has three cameras and the RoboRIO plugged into the bridge. One of the cameras will randomly switch its ip without us changing anything mechanical or with the programming. Does anyone know what could be causing this?
Unread 12-02-2015, 22:23
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Camera IP Keeps Switching
Is the camera set to use DHCP?
If so, did you make the camera names different?
Unread 13-02-2015, 16:19
Halokid Halokid is offline
FRC #0280
Halokid is an unknown quantity at this point
How do we check/do that?
All we did to get the cameras to work before we experienced this problem was set a constant for the camera ip addresses.
