Go to Post Pursue your passion whatever that may be and do not fault another for pursuing theirs. - Mr. Van [more]
Unread 12-02-2015, 20:46
Team3205 Team3205 is offline
FRC #3205
Team3205 is an unknown quantity at this point
Sample Image on the roboRIO cannot be found
We get an error on the FRC DriverStation when we try to enable the robot and the code looks for the image on the roboRIO:
ERROR Unhandled exception java.lang.IndexOutofBoundsException at [java.nio.Buffer.checkIndex(Buffer.java:546), ...
called at line NIVision.imaqReadFile(frame, "/home/lvuser/SampleImage/image20.jpg");
The image is in that path on the roboRIO and we are writing in java any input would be greatly appreciated. Thanks in advance.
Unread 12-02-2015, 20:51
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Sample Image on the roboRIO cannot be found
As described in the comments of the sample program you need to copy the sample image over via FTP if you want to test using it.
Unread 12-02-2015, 22:39
FRC #3205
Ruffles I put the images onto the roboRIO over FTP and I double-checked it, the whole problem originates from the code being unable to find it on the roboRIO even though it is there.
