Go to Post IS THAT A CLUE, DAVE?!?!? - Joe Matt [more]
Unread 12-02-2015, 20:56
MariOlsen MariOlsen is offline
FRC #5416
MariOlsen will become famous soon enough
Solenoid Actuator Legality
Our team is using these solenoid actuators:
http://www.amazon.com/400mA-Frame-So...productDetails
It's a bit late, but we wanted to make absolutely sure we satisfy R18, specifically that they have a "rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC)". Since the specs don't list a power rating, we used P=IV to calculate that (.4A)*(12V)=4.8W. Was this the correct approach? Thanks!
Unread 12-02-2015, 23:44
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Solenoid Actuator Legality
Looks correct to me (MS Physics) - the power can't be any greater than VI. Be sure to bring a copy of (and link to) the "See more product details" page to competition so you can make your case with the inspectors.
Unread 13-02-2015, 00:06
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
Just to let you know. Your PCM will only be able to handle one of those solenoids. The PCM per cross the road's manual can only handle a load of 500mA across the solenoid ports.
If you were going to use a spike relay you can ignore my previous statement.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
"Head Bot Coach" FRC Team 4901 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1102, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 13-02-2015, 00:23
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Absolutely. Solenoids controlled by the PCB (which I hadn't though of because it wasn't stated as a pneumatics issue) have much stricter standards in terms of current/power draw.
Unread 13-02-2015, 10:58
FRC #5416
Thanks! We are using a single Spike to run both.
