Go to Post People should listen to this Andy Baker character, he seems like a smart guy... - Karthik [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 13-02-2015, 09:37
FRC2501's Avatar
FRC2501 FRC2501 is offline
FRC #2501 (Bionic Poalrs)
FRC2501 is an unknown quantity at this point
TalonSRX problem
Our team is using Talon SRXs for our drive this year, but at random times (not while enabled) the SRXs will stop moving the robot, showing a neutral signal but enabled (solid yellow), it takes 1-3 reboots of the robot to get them working again. This issue has brought us to the brink of abandoning the Talon SRXs for the stable Talon SRs.
Here is what troubleshooting we have done:
  1. Try older versions of the robot code
  2. Try just basic drive code
  3. Update Talon SRX firmware to newest version (1.4)
Attached is our robot code
Unread 17-02-2015, 17:01
FRC2501's Avatar
Re: TalonSRX problem
We contacted the manufacturer and they told nus how to fix it
Unread 17-02-2015, 17:10
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
What was the solution?
Unread 17-02-2015, 17:17
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Was it related to this?
http://www.chiefdelphi.com/forums/sh...2&postcount=23
Unread 17-02-2015, 19:40
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
The symptom was that the Talons would go solid orange, and not drive, after enabling the robot. Also DS messages confirmed motor safety trips.
The cause was motor safety tripping. Seems to be a common thing to trip over when using C++ and RobotDrive. Workaround was to RobotDrive::SetSafetyEnabled(false).
Unread 17-02-2015, 23:37
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Wow. That's rather a major showstopper to learn after Australia and most of Asia have bagged!
Unread 18-02-2015, 00:04
ozrien's Avatar
Omar Zrien
AKA: Omar
There are several posts discussing this over the past two weeks. Many of which you posted on.
And by the way, the DS tells you exactly what is wrong, so this isn't very difficult to workaround.
Software can be worked on after after bag.
Unread 18-02-2015, 11:48
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Also, this has been a feature in the code for several years now and is documented in the WPILib material. It's only a showstopper if something like a team sending multiple different Set()s to the same motor in one loop is a showstopper.
