Go to Post Robotics is my football! - Nemo [more]
Unread 13-02-2015, 10:00
Team 4939 Team 4939 is offline
AKA: Anshul Shah
FRC #4939 (All spark 9)
Rookie Year: 2014
Team 4939 is an unknown quantity at this point
Programming of Vex Bumper Switch and Vex Limit Switch
Hello,
Our Team is using elevator to move our arms up and down. The platform runs on 4 chains. We were trying some different tests and we noticed that the chain fell off from the sprocket when going to high or 2 low. We decided to use some switches to make sure the platforms doesn't go 2 far. We decided to use the Vex switches because they already have the PWM cables attached. We hooked them up to the ROBORIO, but our team does not really know how to program them.
Some help with this would be greatly appreciated.
Thanks in Advance.
Unread 13-02-2015, 10:24
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Re: Programming of Vex Bumper Switch and Vex Limit Switch
Have you looked at the Limit Switch tutorial for Java?
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 13-02-2015, 15:00
AKA: Anshul Shah
Rookie Year: 2014
I did run across it, but I noticed that the micro switches that FRC gave us, run through the Digital Input ports, though these Vex Switches run through the PWM ports.
I guess the real question is what is the object name for these switches?
Thank You anyway.
