Go to Post I still believe that if we are legitimately trying to make FRC be recognized as a real sport, then the GDC must treat it like one. - Jim Zondag [more]
Unread 13-02-2015, 10:09
Team 4939 Team 4939 is offline
AKA: Anshul Shah
FRC #4939 (All spark 9)
Rookie Year: 2014
Team 4939 is an unknown quantity at this point
Pneumatics Programming
Hello,
I was just adding the pneumatics code required, and being the rookie I am , I came up with an error. The thing is that I used the code from http://wpilib.screenstepslive.com/s/...for-pneumatics exactly(or so I think) and there seems to be an error. The error message is: Syntax error, insert "AssignmentOperator Expression" to complete Expression. I have posted the code below:
Code:
package org.usfirst.frc.team4939.robot;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
	RobotDrive myRobot;
	Joystick stick;
	int autoLoopCounter;
	Victor victor;
	Compressor c;
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    public void robotInit() {
    	myRobot = new RobotDrive(0,1,2,3);
    	stick = new Joystick(0);
    	victor = new Victor(4);
    	c = new Compressor(0);
    	c->SetClosedLoopControl(true); // THIS SEEMS TO BE THE PROBLEM
     * This function is run once each time the robot enters autonomous mode
    	autoLoopCounter = 0;
     * This function is called periodically during autonomous
    	if(autoLoopCounter < 100) //Check if we've completed 100 loops (approximately 2 seconds)
			myRobot.drive(-0.5, 0.0); 	// drive forwards half speed
			autoLoopCounter++;
			} else {
			myRobot.drive(0.0, 0.0); 	// stop robot
     * This function is called once each time the robot enters tele-operated mode
    public void teleopInit(){
     * This function is called periodically during operator control
    	double rot = -stick.getX();
    	double speed = -stick.getY();
        myRobot.arcadeDrive(speed,rot);
        if(stick.getRawButton(3)){
        	victor.set(1);
        else if(stick.getRawButton(2)){
        	victor.set(-1);
        else{
        	victor.set(0);
        ArmsDouble= new DoubleSolenoid(1, 2);
        ArmsDouble= new DoubleSolenoid(1, 1, 2);
        if(stick.getRawButton(4)){
        	ArmsDouble.set(DoubleSolenid.Value.kForward);
        else if(stick.getRawButton(5)){
        	ArmsDouble.set(DoubleSolenoid.Value.kReverse);
     * This function is called periodically during test mode
    public void testPeriodic() {
    	LiveWindow.run();
Thanks to all in advance.
Unread 13-02-2015, 10:29
Oromus's Avatar
Oromus Oromus is offline
Lead Programmer, Community Liason
AKA: Ryan
FRC #1902 (Exploding Bacon)
Rookie Year: 2013
Oromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to behold
Re: Pneumatics Programming
Change this...
Code:
...to this...
Code:
c.setClosedLoopControl(true);
The "->" needs to be a "." and "Set" needs to become "set". That WPILib example is not showing the code in Java syntax. Also, for future reference, starting this year you don't have to create a Compressor object or do anything with it; if you make any pnuematics-related classes (i.e. Solenoids), the compressor turns on and regulates itself without any code needed. Also, that link appears to be a 2014 code example; you may want to look at 2015 code examples here instead. Good luck with programming!
Unread 13-02-2015, 10:50
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Rookie Year: 2010
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
As Oromus said, that example is in C++. All you're doing is calling a function -- inside the Compressor object there is a function called setClosedLoopControl that takes a boolean as an argument. In Java, that would be articulated as...
Code:
...while in C++ that would be:
Code:
They both do the same thing; they're just differences between languages. It's like comparing apples to oranges -- they both can achieve the same thing (making you less hungry) but the means of doing so is relatively different.
that was a horrible example imsosorry
Unread 13-02-2015, 15:20
AKA: Anshul Shah
Rookie Year: 2014
Code:
Code:
Originally Posted by Oromus View Post
Change this...
Code:
...to this...
Code:
Thank You, very much that seems to have fixed my problem.
Unread 13-02-2015, 15:22
AKA: Anshul Shah
Rookie Year: 2014
Code:
import edu.wpi.first.wpilibj.DoubleSolenoid;
 * directory.
	RobotDrive myRobot;
	Joystick stick;
	Victor victor;
	Compressor c;
			autoLoopCounter++;
			} else {
        	victor.set(1);
        	victor.set(-1);
        else{
        	victor.set(0);
        ArmsDouble= new DoubleSolenoid(1, 2); // THATS SEEMS TO BE THE PROBLEM
        ArmsDouble= new DoubleSolenoid(1, 1, 2);// THAT SEEMS TO BE THE PROBLEM
        	ArmsDouble.set(DoubleSolenoid.Value.kForward);
    	LiveWindow.run();
I seem to have a different problem now.
The error code that shows up is: Multiple markers at this line
- DoubleSolenoid cannot be resolved
to a type
- ArmsDouble cannot be resolved to a
variable
Thank You
Unread 13-02-2015, 15:34
Rakusan2 Rakusan2 is offline
AKA: Tomas Rakusan
FRC #3571 (Milton Mustangs)
Rookie Year: 2011
Rakusan2 is an unknown quantity at this point
Originally Posted by Team 4939 View Post
Code:
 * directory.
	RobotDrive myRobot;
	Joystick stick;
	Victor victor;
	Compressor c;
			autoLoopCounter++;
			} else {
        	victor.set(1);
        	victor.set(-1);
        else{
        	victor.set(0);
    	LiveWindow.run();
to a type
variable
Thank You
You need a declaration for ArmsDouble
Code:
DoubleSolenoid ArmsDouble;
also why are you initializing ArmsDouble twice?
Unread 13-02-2015, 15:39
Oromus's Avatar
AKA: Ryan
Rookie Year: 2013
As Rakusan2 said, you need to declare ArmsDouble somewhere, i.e. "DoubleSolenoid ArmsDouble = new DoubleSolenoid(1, 2)". DoubleSolenoid not being able to resolved may be fixed by that as well.
Unread 13-02-2015, 15:42
AKA: Anshul Shah
Rookie Year: 2014
Code:
If I am using a Double Solenoid do I not need to initialize it twice for both the In and Out feature?
That's the impression this gave me: http://wpilib.screenstepslive.com/s/...ders-solenoids
Unread 13-02-2015, 15:46
AKA: Tomas Rakusan
Rookie Year: 2011
No, a single declaration and initialization of DoubleSolenoid takes care of both solenoids
Oromus's Avatar
AKA: Ryan
Rookie Year: 2013
That example was just showing the different ways you can initialize your DoubleSolenoid; you do one constructor or the other.
Unread 15-02-2015, 00:38
viggy96 viggy96 is offline
FRC #3331
Rookie Year: 2010
viggy96 is infamous around these partsviggy96 is infamous around these partsviggy96 is infamous around these parts
DoubleSolenoid(in channel, out channel). Also, the compressor does not need to be instantiated. The compressor is on a closed loop controlled by the PCM. You just need to instantiate the DoubleSolenoid once, and and set the position on button values.
