Go to Post Programming isn't that hard once you get the hang of it. It has a steep learning curve like math. One day your trying to figure out 1 1, then the next day they throw x and y at you. Once you understand what x and y represent and learn to think in terms of functions, it's as easy as pi. - sciguy125 [more]
Unread 13-02-2015, 11:25
random.hero random.hero is offline
FRC #3297
random.hero is an unknown quantity at this point
Need Help Limiting Max Joystick Input
I'd like to limit the maximum power that our joystick outputs at 100% push down to say 50% output or so. I've attached a pic of our code as I apparently do things a little bit differently than others do as far as coding my joysticks. Any help would be appreciated. Thanks!
Unread 13-02-2015, 11:39
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Need Help Limiting Max Joystick Input
It seems there are quite a few teams wanting to limit motor voltage at the 11th hour. Bad choice of gearing maybe?
http://www.chiefdelphi.com/forums/sh...d.php?t=134474
Unread 13-02-2015, 11:41
FRC #3297
Last minute change of drive system from 6 super grips to 4 mechs. Too much power/speed now so want to tame it a little bit.
Unread 13-02-2015, 12:52
RobotMonkey RobotMonkey is offline
FRC #1413
RobotMonkey is an unknown quantity at this point
Fastest way is to just multiply each of the axes going into the drive by some constant between 0 and 1. If you wan to halve it, multiply each by 0.5
Unread 13-02-2015, 13:06
Ether's Avatar
Rookie Year: 1969
Just so that rookie teams contemplating doing this do so with eyes wide open:
http://www.chiefdelphi.com/forums/sh...2&postcount=25
http://www.chiefdelphi.com/forums/sh...4&postcount=19
http://www.chiefdelphi.com/forum/sho...30#post1426530
Unread 13-02-2015, 15:06
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
That looks like code from last year. The 2015 Joystick functions return the axes and buttons as arrays, not as bundles.
Unread 15-02-2015, 00:32
viggy96 viggy96 is offline
FRC #3331
Rookie Year: 2010
viggy96 is infamous around these partsviggy96 is infamous around these partsviggy96 is infamous around these parts
Just use the multiply block and multiply the joystick input by a decimal before sending it to the drive block.
Unread 15-02-2015, 23:06
netmizor's Avatar
netmizor netmizor is offline
FRC #1413
netmizor is an unknown quantity at this point
I believe this should work. Use the controls on the front end of the teleop.vi to establish desired top speeds then hard code them.
