Go to Post Ice cream is an iterative process. - JVN [more]
Unread 13-02-2015, 12:53
AnnaliseDonavan AnnaliseDonavan is offline
FRC #4284
AnnaliseDonavan is an unknown quantity at this point
Exclamation Code problem
the code runs but when it comes to pressing the buttons nothing happens
package org.usfirst.frc.team4284.robot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.buttons.JoystickButton;
import edu.wpi.first.wpilibj.buttons.Button;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
RobotDrive Drive;
Joystick drivestick;
Joystick joystick;
int autoLoopCounter;
* This function is run when the robot is first started up and should be
* used for any initialization code.
public void robotInit() {
Jaguar FL = new Jaguar (5);
Jaguar BL = new Jaguar (2);
Jaguar FR = new Jaguar (3);
Jaguar BR = new Jaguar (4);
Drive = new RobotDrive(FL,BL,FR,BR);
drivestick = new Joystick(0);
joystick = new Joystick(1);
* This function is run once each time the robot enters autonomous mode
autoLoopCounter = 0;
* This function is called periodically during autonomous
/*if(autoLoopCounter < 100) //Check if we've completed 100 loops (approximately 2 seconds)
Drive.drive(-0.5, 0.0); // drive forwards half speed
autoLoopCounter++;
} else {
Drive.drive(0.0, 0.0); // stop robot
* This function is called once each time the robot enters tele-operated mode
public void teleopInit(){
* This function is called periodically during operator control
Drive.arcadeDrive(drivestick);
Button button1 = new JoystickButton(joystick, 1),
button2 = new JoystickButton(joystick, 2),
button3 = new JoystickButton(joystick, 3),
button4 = new JoystickButton(joystick, 4),
button5 = new JoystickButton(joystick, 5),
button6 = new JoystickButton(joystick, 6),
button7 = new JoystickButton(joystick, 7),
button8 = new JoystickButton(joystick, 8),
button9 = new JoystickButton(joystick, 9),
button10 = new JoystickButton(joystick, 10),
button11 = new JoystickButton(joystick , 11);
button1.whenPressed(new ElevatorOff());
button2.whenPressed(new ElevatorOn());
button3.whenPressed(new ElevatorReverse());
button4.whenPressed(new ArmsOut());
button5.whenPressed(new ArmsIn());
button6.whenPressed(new ArmsVerticalIn());
button7.whenPressed(new ArmsVarticalOut());
button8.whenPressed(new BlueLightShow());
button9.whenPressed(new LigthShowOn());
button10.whenPressed(new RedLightShow());
button11.whenPressed(new LightShowEnd());
* This function is called periodically during test mode
public void testPeriodic() {
LiveWindow.run();
Unread 13-02-2015, 13:22
Adamz_'s Avatar
Adamz_ Adamz_ is online now
Who wants coffee?
AKA: Connor Adams
FRC #4519 (Kings Mechavaliers)
Rookie Year: 2013
Adamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to behold
Re: Code problem
Based on the block of code below, i feel its safe to assume that you have differnt classes for all of the commands you wish to run once the button is pressed, and it would be easier to diagnose if you posted your full robot code.
If this is infact your only class, your attempting to refernce a null command, so the button press is trying to reach a null comand, in result doing nothing.
Originally Posted by AnnaliseDonavan View Post
Code:
2016 North Bay Regional Finalists
2016 Greater Toronto Central Regional Semi-Finalists
2015 Windsor Essex Great Lakes Regional Quarter-Finalists
2014 Windsor Essex Great Lakes Regional Semi-Finalists
2014 Waterloo Regional Quarter-finalists
2013 Waterloo Regional Highest Rookie Seed
2013 Waterloo Regional Rookie All Star Recipient
Unread 13-02-2015, 13:27
FRC #4284
Re: Code problem
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.command.Command;
public class ArmsIn extends Command {
@Override
protected void initialize() {
// TODO Auto-generated method stub
@Override
protected void execute() {
Talon LeftArm = new Talon(9);
Talon RightArm = new Talon(8);
LeftArm.set(1);
RightArm.set(-1);
try {
Thread.sleep(500); //stop for 1/2 second
} catch(InterruptedException ex) { // allows for interruption of the sleep period
Thread.currentThread().interrupt();
LeftArm.set(0);
RightArm.set(0);
@Override
protected boolean isFinished() {
return false;
@Override
protected void end() {
@Override
protected void interrupted() {
public class ArmsOut extends Command {
@Override
@Override
Talon RightArm = new Talon(9);
Talon LeftArm = new Talon(8);
LeftArm.set(-1);
RightArm.set(1);
try {
LeftArm.set(0);
RightArm.set(0);
@Override
return false;
@Override
@Override
public class ArmsVarticalOut extends Command {
@Override
@Override
Talon In_Out = new Talon(7);
Talon In__Out = new Talon(0);
In_Out.set(-1);
In__Out.set(-1);
try {
In_Out.set(0);
In__Out.set(0);
@Override
return false;
@Override
@Override
public class ArmsVerticalIn extends Command {
@Override
@Override
Talon In_Out = new Talon (7);
In_Out.set(1);
In__Out.set(1);
try {
In_Out.set(0);
In__Out.set(0);
@Override
return false;
@Override
@Override
import edu.wpi.first.wpilibj.Relay;
public class BlueLightShow extends Command {
@Override
@Override
Relay relay1 = new Relay(0);
Relay relay2 = new Relay(1);
relay1.set(Relay.Value.kOn);
relay2.set(Relay.Value.kOff);
@Override
return false;
@Override
@Override
public class ElevatorOff extends Command {
@Override
@Override
Jaguar Elevator1 = new Jaguar(5);
Jaguar Elevator2 = new Jaguar(0);
Elevator1.set(0);
Elevator2.set(0);
@Override
return false;
@Override
@Override
public class ElevatorOn extends Command {
@Override
@Override
Elevator1.set(.25);
Elevator2.set(.25);
@Override
return false;
@Override
@Override
public class ElevatorReverse extends Command {
@Override
@Override
Elevator1.set(-.25);
Elevator2.set(-.25);
@Override
return false;
@Override
@Override
public class LightShowEnd extends Command {
@Override
@Override
relay1.set(Relay.Value.kOff);
@Override
return false;
@Override
@Override
public class LigthShowOn extends Command {
@Override
@Override
relay1.set(Relay.Value.kReverse);
relay2.set(Relay.Value.kOn);
try {
Thread.sleep(5000); //stop for 1/2 second
//Turn on lights Blue and Green)
relay2.set(Relay.Value.kReverse);
try {
// Turns on blue and red lights
relay2.set(Relay.Value.kForward);
try {
@Override
return false;
@Override
@Override
public class RedLightShow extends Command {
@Override
@Override
@Override
return false;
@Override
@Override
