Go to Post My lasting impression of 217 (for years now) has been based on how their robot looks, dynamically. It is poultry in motion. :) - Richard Wallace [more]
Unread 19-12-2001, 20:04
Andrew Wyatt Andrew Wyatt is offline
#0524 (Alpha Omega Robotics)
Andrew Wyatt is an unknown quantity at this point
Send a message via AIM to Andrew Wyatt
45 or 75 amp anderson power products connectors to drill motors?
In preparation for next season, we are ordering things like connectors so we will have them on hand when we need them.
are the 45 amp powerpole connectors adiquite for use with the drill motors or should we go with the much larger 75 amp connectors?
There are only two tools you really need: duct tape and Wd40. if it moves and it shouldn't, use the tape. if it should move and doesn't, use the wd40.
Unread 20-12-2001, 00:05
Paul Marshall Paul Marshall is offline
Paul Marshall will become famous soon enough
Send a message via AIM to Paul Marshall
you only really need the 45 amp connectors because the max current that a drill motor can draw is 20 amps. that is because of the auto-reset fuse that must be put in series with it. you do gain a little power if useing the 75 amp connector, but the gain is negligible. so i would say go with the 45 amp connectors.
-Paul
Unread 20-12-2001, 08:00
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
The only place we have ever used the big connector is on the battery line. The smaller connectors work just fine for all other needed (in terms of current in any case).
Joe J.
4WD with 4 motors archiver 2001 8 23-06-2002 22:58
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drill Motors TF8 Motors 19 12-12-2001 13:13
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
