Go to Post Win, Lose or Tie, but do it in a way that FIRSTers will be talking about for years to come! - Bill Moore [more]
Thread Tools Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Unread 13-02-2015, 13:43
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Low tech (simply MSWord) robot numbers aren't that easy
When reading the rules, I made the assumption that the blue box under R2 was implying that you could just select the suggested font and size, print in landscape and quickly print your legal team number on any typical laser printer on 8.5x11 paper.
I actually tried this with our team number (4859) and it took me about 5 attempts to meet all the requirements.
For my setup, using MS Word 2013, Landscape setup, I set the font to Impact, size 323, and then had to go to the Advanced tab in Font settings, set Spacing to Condensed, and set the Condensed 'By:' value to 10 pt. (Larger number here scrunches numbers together more) I set margins to 1".
This satisfied nearly everything-- the left margin was slightly < 1" and a small portion of the '5' where the curved part meets the vertical and the small join point on the '9' was < .5".
Oh, and the font color was black and the paper was white 8.5"x11"
I arrived at the font size by printing in the recommended point size which was bigger than needed, and then calculating the percentage overage, and using that to determine the point size that would result in 3.5" numbers exactly (and suprisingly, .5" stroke on the narrowest sustained stroke.) I guess the recommended 362 pt font may meet the .5" stroke.
Of course, if you print on wider paper (e.g. 8.5 x 14) then you can use a larger font, but I have access to lamination at only 8.5 x 11.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 13-02-2015, 14:47
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Low tech robot numbers aren't that easy
I think we spent two days, with two or three students working on the problem.
They found a font with a mostly constant stroke width, of just over .5" when printed at 3.5" height, and then did some magic with horizontal spacing and shrinking to fit it on the paper.
Everything is a challenge.
Unread 13-02-2015, 14:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Inkscape? Two pieces of paper?
I'm very worried about this year if such a simple task as numbers presents this much of a challenge.
Unread 13-02-2015, 15:22
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
I know that in GIMP (I have never actually downloaded photoshop) you can set a size in inches for an image. Shouldn't this simplify the numbers? Might be a little tedious, but at the very least you could make each individual number as its own image and then print them and paste them next to eachother.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 13-02-2015, 15:28
MrForbes's Avatar
AKA: Jim
That's easy for you to say, Mr. three-digit-team-number!
Unread 13-02-2015, 15:30
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Well... I'd think that 1/2in wide black electrical tape would get the job done... But hey, I'm just a mechanical guy, not a graphical designer.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 13-02-2015, 15:44
Abhishek R Abhishek R is offline
FRC #0624
Rookie Year: 2012
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Some software, like Adobe Illustrator, Inkscape, and GIMP will let you set the dimensions of your canvas to inches, then you can work off of that. It's like CAD for images, literally.
I believe the last two I listed are free, last time I checked. Inkscape especially is particularly nice, for a free product, though I personally prefer Macromedia Fireworks/Illustrator.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 13-02-2015, 16:01
My primary point was that the Blue Box seemed to lead you toward a minimal solution using a common word processor font, but going down that path led to far more issues that I would have guessed. Yes, there are lots of ways to make it work that are slightly more involved than opening MSWord and setting font and font size.
Teams that are ignoring the number issue until the last minute and figuring they'll just whip something up in MSWord and print on card stock or laminate something will get frustrated and/or not pass inspection.
John Vriezen
Unread 13-02-2015, 23:33
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
I dusted off some decades-old tech and developed a postscript solution meeting the specs and fitting on a US letter page. Most of the strokes are about 5/16", none that I saw under 9/32". The sample below actually has three separate numbers: 3946, 0125, and 7844.
These were chosen based on my team's number, including all ten digits, and the fact that "4" is the widest digit. Just use one of the blocks of code and replace the appropriate four digits with your team number. (1, 2, and 3 digit teams can delete one or more of the first three digit lines):
Code:
%!PS-Adobe
20 setlinewidth 0 setgray
/Helvetica findfont 350 scalefont setfont
/showchar {currentpoint 2 index false charpath stroke
           moveto               true  charpath fill} def
90 rotate 0 -500 translate
0.75 1 scale
27 setlinewidth 1 setlinejoin
130 108 moveto (3) showchar
330 108 moveto (9) showchar
540 108 moveto (4) showchar
750 108 moveto (6) showchar  showpage
0.75 1 scale
120 108 moveto (0) showchar
330 108 moveto (1) showchar
540 108 moveto (2) showchar
750 108 moveto (5) showchar showpage
0.75 1 scale
120 108 moveto (7) showchar
330 108 moveto (8) showchar
750 108 moveto (4) showchar showpage
If you have linux, you can use it pretty directly. If you have windows, you'll have to get ghostscript and ghostview (gs and gsview). I'm attaching PDFs of my sample file so those with windows can preview it.
