Thread Tools |
Rating:
Display Modes |
Eclipse WPILib Problem C++
Hey everyone,
Our team is having a problem with connecting WPILib to Eclipse. The problem is that where we have errors is in the code that we didn't write. Our main problems are in VictorSP, Digital Input, and Joystick. Joystick won't connect, no matter what we do. For VictorSP, we have errors that say "must implement pure virtual method SpeedController::Set". In Digital Input, we have errors that say "must implement pure virtual method InterruptableSensorBase". Does anyone know what to do? Thanks, ShadathChow |
Re: Eclipse WPILib Problem C++
This sounds a bit odd to me. The only thing coming to mind at the moment is that I have seen strange errors (maybe not THIS strange though) with new projects until executing a right-click on the project (left pane) and select Index->Rebuild.
Possibly you need an update of the WPI plugin? If you went through the screensteps very carefully, you will have set your preferences to auto update. Maybe check to see if that's still 'set' right? Preferences... Updates->AutoUpdate and check the checkbox for allowing automatic updates. You can also manually check for updates via Help->Check for updates. Let us know what you find! |
This isn't likely not be related, but thought I would mention this C++ driver station update just in case.
http://www.usfirst.org/sites/default...Bundle0210.pdf |
Note that I am attempting to answer this question having not looked at the WPILib in several years...
The error you are describing sounds like you are trying to instantiate an interface rather than a fully implemented class. Posting a code snipit might help diagnose the exact problem. Do you have a line in your code like: Code:
SpeedController sc = new SpeedController(); Code:
SpeedController sc = new IVictorSP(); Code:
SpeedController sc = new VictorSP(); Check your documentation and make sure you are instantiating the correct class. |
Do you at least see an FRCUserProgram binary under the Binaries tree node in the Project explorer? If so then your code is building ok, in which case the IDE parser is likely showing stale info. In which case this should fix it....
http://www.chiefdelphi.com/forums/sh...63&postcount=5 |
http://wpilib.screenstepslive.com/s/...to-the-roborio
Look at the eclipse screenshots. There is a tree node called "Binaries" in the project explorer. It's above "Includes", which is above "Debug", etc... |
