Go to Post Honestly, no one at a FIRST competition is gonna judge you. Chances are, there are least 20 people dorkier than you. - JohnnyB [more]
Unread 13-02-2015, 16:07
BrighidKHeh's Avatar
BrighidKHeh BrighidKHeh is offline
FRC #3871 (Trojan Robotics)
Rookie Year: 2011
BrighidKHeh is an unknown quantity at this point
Trouble with Eclipse (Java)
public Joystick joystick1;
public JoystickButton NoodleOn;
public JoystickButton NoodleOff;
public Joystick LiftArm;
public Joystick joystick2;
public IO() {
rightJoystick = new Joystick(1);
joystick2 = new Joystick(2);
NoodleOn = new JoystickButton(joystick2, 3);
NoodleOn.whileHeld(new NoodleOn());
___________________________________________
The two bolded Joysticks (joystick(1) and joystick(2)) contain errors. The errors says "cannot instantiate the type joystick". The code shouldn't be producing errors, and joystick.class is under the WPILIB like it should be. Any solutions?
the image is under a word document
Unread 13-02-2015, 16:24
Rakusan2 Rakusan2 is offline
AKA: Tomas Rakusan
FRC #3571 (Milton Mustangs)
Rookie Year: 2011
Rakusan2 is an unknown quantity at this point
Re: Trouble with Eclipse (Java)
I do not see rightJoystick being declared
Code:
public Joystick rightJoystick;
also this year the numbering for joysticks is 0-based meaning that the 1st joystick is Joystick(0)
Unread 13-02-2015, 16:35
Rookie Year: 2011
public Joystick ArmUpDown;
public Joystick leftJoystick;
public IO() {
leftJoystick = new Joystick(2);
NoodleOn = new JoystickButton(2, 3);
ArmUpDown = new Joystick(1);
The bolded joysticks all have the same error still. "Cannot instantiate the type joystick". Also, when I click on joystick.class under WPILib, I get a page that says "Source not found - The JAR file has no source attachment". I don't know if this makes a difference or not.
Unread 13-02-2015, 17:35
Rookie Year: 2011
Re: Trouble with Eclipse (Java)!!!
Is there anyone who is good at Java and would be willing to use TeamViewer?
Unread 13-02-2015, 17:41
AKA: Tomas Rakusan
Rookie Year: 2011
Are you able to show me the rest of the class?
Unread 13-02-2015, 17:48
Rookie Year: 2011
public class ArmDown extends Command {
public ArmDown() {
// Use requires() here to declare subsystem dependencies
// eg. requires(chassis);
requires(Robot.noodleAndToteSystems);
// Called just before this Command runs the first time
protected void initialize() {
// Called repeatedly when this Command is scheduled to run
protected void execute() {
Robot.noodleAndToteSystems.SetArmMotorSpeed(-1);
// Make this return true when this Command no longer needs to run execute()
protected boolean isFinished() {
return false;
// Called once after isFinished returns true
protected void end() {
Robot.noodleAndToteSystems.SetArmMotorSpeed(0);
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
protected void interrupted() {
return arm.limitSwitch3;
return arm.limitSwitch4;
end();
The error is at the top of this page, and every other page in the program.
Unread 13-02-2015, 23:54
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Rookie Year: 2010
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Well, the first thing I've noticed is that your Joystick ports are off -- it starts at a zero-index so Joystick 1 is in port 0 and Joystick 2 is in port 1.
Unread 15-02-2015, 00:31
viggy96 viggy96 is offline
FRC #3331
Rookie Year: 2010
viggy96 is infamous around these partsviggy96 is infamous around these parts
Did you import the Joystick class?
Unread 15-02-2015, 00:59
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Rookie Year: 2012
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
you have to create the object outside the constructor like so Oi.java
