Go to Post There are a maximum of 80 balls in play . If all the balls are in the goals or out of play and the human players won't throw them back in, I guess the robots might try line dancing or doing the cha-cha. - Rick TYler [more]
Unread 13-02-2015, 22:10
loganzip loganzip is offline
FRC #2838
loganzip is an unknown quantity at this point
Pneumatic Double Soliniod
I am programming pneumatic. I have gotten the compressor to turn on and the pressure switch to work. but I can not figure out how to program a double soliniod to a button. Here is the code I have for the button.
if (SpecialOps.GetRawButton(1))
Launcher2Sol.Set(DoubleSolenoid::kReverse);
else
Launcher2Sol.Set(DoubleSolenoid::kForward);
I am using the trigger on the Logitech 3D extreme pro controller. Anyone able to help me?
Unread 13-02-2015, 22:24
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Pneumatic Double Soliniod
Can you post all of your code?
