Go to Post Us, as adults, find ways to help the kids to make it happen. - aspiece [more]
Unread 14-02-2015, 00:20
Zalmay's Avatar
Zalmay Zalmay is offline
FRC #4528
Zalmay is an unknown quantity at this point
Need help programming Double Solenoids!
Hello again, I know I have posted this before but I have made slight modifications to the code and wondered if anyone could take a look at it to see if it has any errors. I ask this because when we tested it, it did not work. The A and B buttons were pressed, it just wasn't moving the piston. I have checked the CAN ID and made sure it is the same as the value I initialized it in the code, so that's not likely to be an issue. Thanks for the help in advance guys.
Robot.java:
Code:
package org.usfirst.frc.team4528.robot;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Victor;
public class Robot extends SampleRobot
	Victor frontLeft;
	Victor rearLeft;
	Victor frontRight;
	Victor rearRight;
	Victor motor;	//add-on
    RobotDrive myRobot;
    XBoxJoystick stick;
    Compressor compressor;
    DoubleSolenoid piston;
    public Robot()
    	frontLeft = new Victor(2);
    	rearLeft = new Victor(3);
    	frontRight = new Victor(0);
    	rearRight = new Victor(1);
    	motor = new Victor(4);		//add-on
        myRobot = new RobotDrive(frontLeft, rearLeft, frontRight, rearRight);
        stick = new XBoxJoystick(0);
        compressor = new Compressor();	//null parameter
        piston = new DoubleSolenoid(0, 4, 5);
        //CAN ID is first parameter(null if 0), second parameter is forward port and
        //third parameter is reverse port
  //add-on
  	public void runMotor()
          	if(stick.getLeftZ() > 0 && stick.getRightZ() == 0)		//Changed so not functional if both pressed
          		motor.set(stick.getLeftZ());
          	else if(stick.getRightZ() > 0 && stick.getLeftZ() == 0)	//Changed so not functional if both pressed
          		motor.set(-stick.getRightZ());
          	else
          		motor.set(0.0);
  	public void moveArm()
  		compressor.start();
  		compressor.setClosedLoopControl(true);
  		if(stick.getAButton() == true && stick.getBButton() != true)
  			piston.set(DoubleSolenoid.Value.kForward);
  		else if(stick.getBButton() == true && stick.getAButton() != true)
  			piston.set(DoubleSolenoid.Value.kReverse);
  		else
  			piston.set(DoubleSolenoid.Value.kOff);
     * Drive left & right motors for 2 seconds then stop
    public void autonomous()
    	while(isAutonomous() && isEnabled())
    		//Drives full forward for 5 seconds then stops
    		myRobot.drive(1.0, 0.0);
    		Timer.delay(5.0);
    		myRobot.drive(0.0, 0.0);
     * Runs the motors with arcade steering.
    public void operatorControl()
        myRobot.setSafetyEnabled(false);
        while (isOperatorControl() && isEnabled())
            myRobot.arcadeDrive(0.6*stick.getLeftY(), -0.6*stick.getRightX(), true);
            Timer.delay(0.005);		// wait for a motor update time
            runMotor();
     * Runs during test mode
    public void test()
XBoxJoystick.java:
Code:
public class XBoxJoystick
	private Joystick joystick;
    private int port;
    private final double DEAD_ZONE = 0.08; // Chief Delphi said 0.05;
    public XBoxJoystick(int port)
            this.port = port;
            this.joystick = new Joystick(port);
    public double getLeftX()
            return correctDeadSpot(joystick.getRawAxis(0));
    public double getLeftY()
            return correctDeadSpot(joystick.getRawAxis(1));
    public double getLeftZ()
        return joystick.getRawAxis(2);
    public double getRightZ()
        return joystick.getRawAxis(3);
    public double getRightX()
            return correctDeadSpot(joystick.getRawAxis(4));
    public double getRightY() {
            return correctDeadSpot(joystick.getRawAxis(5));
    public double getDpadX()
            return joystick.getRawAxis(6);
    // WARNING this doesn't work with vanilla driver station
    public double getDpadY()
            return joystick.getRawAxis(7);
    public boolean getAButton()
            return getButton(1);
    public boolean getBButton()
            return getButton(2);
    public boolean getXButton()
            return getButton(3);
    public boolean getYButton()
            return getButton(4);
    public boolean getLBButton()
            return getButton(5);
    public boolean getRBButton()
            return getButton(6);
    public boolean getBackButton()
            return getButton(7);
    public boolean getStartButton()
            return getButton(8);
    public boolean getLSButton()
            return getButton(9);
    public boolean getRSButton()
            return getButton(10);
    private double correctDeadSpot(double value)
            if (Math.abs(value) < DEAD_ZONE)
                    return 0;
            return value;
    private boolean getButton(int buttonNumber)
            return joystick.getRawButton(buttonNumber);
Unread 14-02-2015, 00:43
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Need help programming Double Solenoids!
You never call moveArm() in operatorControl(), which appears (to my tired brain) to be at least some of your issue.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 14-02-2015, 09:08
Zalmay's Avatar
FRC #4528
How silly of me to forget. Thank you for pointing it out to me. One more question however. When I did build the code and test it the compressor still ran despite the command for it to start and stay in a closed loop being inside the moveArm() method I did not call, does anyone know why that it?
Thanks in advance.
Unread 14-02-2015, 09:19
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The compressor is automatically engaged whenever you have instantiated a solenoid.
You don't need to instantiate the compressor and your Start is redundant.
