Go to Post Best way to get the word out for FIRST is Demo, Demo, Demo. There's no reason anyone in your community shouldn't know what you folks are doing. - Martinez [more]
Unread 14-02-2015, 02:59
Cattmy Cattmy is offline
FRC #3328 (NohoRobo)
Team Role: Leadership
Rookie Year: 2014
Cattmy is an unknown quantity at this point
Trying to Remove Mini-CIM from Toughbox; Wheels Stuck
In an attempt to cut down on weight, we have decided to remove the additional Mini-CIM motor from each of our four Toughbox Minis. We tried to pull our 8" mecanum wheels off the toughbox axles to no avail. Any suggestions on how to proceed?
Thanks in advance!
Unread 14-02-2015, 08:12
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Re: Trying to Remove Mini-CIM from Toughbox; Wheels Stuck
Both the AndyMark and VexPro are supported on the shaft by two hubs, one on each side of the plates/bodies. If the two hubs become misaligned to each other (axes not parallel or axes parallel but not coincident), they can jam on the shaft. You might try loosening the screws that hold the hubs onto the plates/bodies.
We have had similar problems getting shafts into the new clamping gearboxes and bearing blocks. The shaft is a slip fit onto the bearings leaving very little tolerance for misalignment between the two bearings.
Unread 14-02-2015, 09:11
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Get a pulley puller. Your local hardware store should have a variety of options. If you can, bring the whole TB/wheel assembly to the store so you can find something that will be the right size.
