Go to Post Instead of "Team XXXX graciously accepts" how about just a big "yeaaaahhhhh!" ? - sanddrag [more]
Unread 14-02-2015, 05:54
vasa.dhananjay vasa.dhananjay is offline
FRC #4748
vasa.dhananjay is an unknown quantity at this point
PWM output not working?
Just got into the programming a few days ago. Suffice to say I'm trying to get the drive system working. For some reason when I run any of the examples, the PWM output doesn't work at all. I'm not sure what to look for and getting a little desperate!!
I've verified that the hardware setup is correct. Jumping signal wire to 6V gets the motor going so I know that that's working. I've hooked up the PWM signal to an oscilloscope as well.
My setup is a single motor attached to a Victor 884 with input coming from PWM 0 on the RoboRIO. Joystick is also attached.
Unread 14-02-2015, 08:39
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: PWM output not working?
That doesn't sound right. I know you say the hardware is correct, but if the examples don't work it's still the first place to start. Please describe your hardware setup, telling us exactly where each wire is connected. Pictures would help.
