Go to Post ...Of course, all the scales in the world won't help you if your robot is 135lb two nights before the ship date... - J Flex 188 [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 24-06-2002, 02:55
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
optical sensor
Posted by joe frick at 03/27/2001 12:14 PM EST
Engineer on team #466, bartram braves, from john bartram high school and sheet metal workers local union 19.
could anyone help me with the optical sensor?
i want to use it as a limit switch how do i hook it up to digital imputs to control PWM 3 what i need is something that lets me start a match in a down position but prevent our robot from returning to this position during a match, so the switch would have to allow our robot to go up but not down. any help wou;ld be appreciated
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: optical sensor
Posted by Lloyd Burns at 03/27/2001 4:58 PM EST
Engineer on team #188, Woburn Robotics, from Woburn Collegiate and TorDistSchoolBrd, ScotiaBank. OntPwrGen, Enbridge.
In Reply to: optical sensor
Posted by joe frick on 03/27/2001 12:14 PM EST:
: could anyone help me with the optical sensor?
: i want to use it as a limit switch how do i hook it up to digital imputs to control PWM 3
' see the connection diagram on the case, and the listing of the pinouts in the Innovation First manual.
One of the wires goes to ground, one to the +5 V pin, and one (of the two outputs) to the signal pin. One of the outputs is closed normally, but opens when it detects reflection; the other output closes at the same time. Closed to ground = 1 in the program.
: what i need is something that lets me start a match in a down position but prevent our robot from returning to this position during a match, so the switch would have to allow our robot to go up but not down. any help wou;ld be appreciated
' if rc_sw# = 1 then PWM3 = 0 (or 254 depending on how you've wired the motor.) This could compress into
PWM3 = 127 + rc_sw# * 127 (if 254 is up, or use - to get to 0).
' you could implement another limit switch or a timer / counter to make sure the part rose far enough, if your sensor is positioned to sense only the start.
#0047 (ChiefDelphi)
Re: optical sensor
Posted by Travis Hoffman at 03/27/2001 10:18 PM EST
Engineer on team #48, Delphi E.L.I.T.E., from Warren G. Harding High School and Delphi Automotive Systems .
In Reply to: Re: optical sensor
Posted by Lloyd Burns on 03/27/2001 4:58 PM EST:
: : could anyone help me with the optical sensor?
: : i want to use it as a limit switch how do i hook it up to digital imputs to control PWM 3
: ' see the connection diagram on the case, and the listing of the pinouts in the Innovation First manual.
: One of the wires goes to ground, one to the +5 V pin,
The optical sensor runs on 12 VDC. Tap the power for the device from the 20A Robot Controller circuit breaker.
Travis
: : what i need is something that lets me start a match in a down position but prevent our robot from returning to this position during a match, so the switch would have to allow our robot to go up but not down. any help wou;ld be appreciated
: ' if rc_sw# = 1 then PWM3 = 0 (or 254 depending on how you've wired the motor.) This could compress into
: PWM3 = 127 + rc_sw# * 127 (if 254 is up, or use - to get to 0).
: ' you could implement another limit switch or a timer / counter to make sure the part rose far enough, if your sensor is positioned to sense only the start.
#0047 (ChiefDelphi)
Yer Right - 12 V :-(
Posted by Lloyd Burns at 03/28/2001 6:27 PM EST
Posted by Travis Hoffman on 03/27/2001 10:18 PM EST:
: The optical sensor runs on 12 VDC. Tap the power for the device from the 20A Robot Controller circuit breaker.
: Travis
[IMG] code is Off
optical sensor majormusic2005 Technical Discussion 1 29-01-2003 07:39
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
Find any optical sensor in catalogs? GreenDice Programming 1 13-01-2003 18:05
How do you connect optical sensor? archiver 2001 1 23-06-2002 23:05
Optical range sensor Ben Mitchell Technical Discussion 9 12-01-2002 00:11
