Go to Post A good robot with great strategy beats a great robot with good strategy. - Brian Maher [more]
Unread 14-02-2015, 10:18
BLUEBELL BLUEBELL is offline
FRC #3773
BLUEBELL is an unknown quantity at this point
Axis Camera
How can I use an Axis Camera to send a camera feed without using Vision in Java?
Unread 15-02-2015, 09:18
CreativeName55 CreativeName55 is offline
FRC #2729 (Storm Robotics)
Rookie Year: 2011
CreativeName55 is an unknown quantity at this point
Re: Axis Camera
What do you mean? You just want the basic camera view to come up on smartdashboard or something without doing any vision processing?
Unread 16-02-2015, 15:16
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
Team Role: Leadership
Rookie Year: 2013
JacobD is an unknown quantity at this point
Re: Axis Camera
Code:
import edu.wpi.first.wpilibj.vision.AxisCamera;
AxisCamera cam1 = new AxisCamera("10.XX.XX.X"); //put in your camera's ip
public static AxisCamera.Resolution k640x360;
https://wpilib.screenstepslive.com/s...an-axis-camera
Follow those instructions exactly then...
Put this into your code.
Unread 16-02-2015, 20:07
FRC #3773
Re: Axis Camera
Will that display the camera on the dashboard?
Unread 16-02-2015, 20:25
JacobD's Avatar
AKA: Jacob
Rookie Year: 2013
Re: Axis Camera
Yes it will, you just have to go to your dashboard and add the camera with the ip.
Unread 17-02-2015, 20:10
FRC #3773
Re: Axis Camera
Where do I go on the dashboard to add the camera?
Unread 17-02-2015, 20:43
JacobD's Avatar
AKA: Jacob
Rookie Year: 2013
Re: Axis Camera
I believe it is somewhere on the bottom right side. It lets you choose from Ip Camera, HW Webcam, or SW Webcam.
Unread 18-02-2015, 12:16
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
Rookie Year: 2012
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Re: Axis Camera
Are you using SmartDashboard or SmartDashboard 2 (SFX)?
