Go to Post You can make unfounded guesses, but chances are you'll come off looking like a moron. Let's try and avoid that. - Karthik [more]
Unread 14-02-2015, 14:33
HostileGato HostileGato is offline
FRC #4005
HostileGato is an unknown quantity at this point
Trouble Displaying USB camera stream to Dashboard
I am having trouble displaying camera feed to the dashboard. I am using the default mecanum labview code with a USB camera plugged into the roboRIO. I've checked to make sure my camera is recognized when connected to the robioRIO over USB. However i'm still not able to see the camera feed from my dashboard. When I deploy the code to the roboRIO I get these error messages: ERROR-1074360311 occured at IMAQdx Open Camera.vi and NI-IMAQdx: (Hex0xBFF69009) Camera not found . I've also tried enabling vision on the Robot Main VI front Panel.
Unread 15-02-2015, 09:45
Re: Trouble Displaying USB camera stream to Dashboard
In the Vision VI, it lets you specify the camera address and lets you choose between a name for an Axis camera and a name for a USB camera. What name is that code selecting? By default, it was looking for the first USB camera.
Greg McKaskle
Unread 15-02-2015, 12:21
FRC #4005
By camera address do you mean what port it is physically plugged into on the roboRIO? In other words, does the the USB camera have to be plugged into a certain USB port on the roboRIO? I believe in my code the name for the camera is just "Camera". I don't have access to check right now, but i believe when connected to the roboRIO over USB it doesn't list the USB camera's name as "Camera". Here is a screenshot of the code I am using.
http://s1341.photobucket.com/user/ts...tml?sort=3&o=0
Unread 15-02-2015, 14:50
Nunez4296's Avatar
Nunez4296 Nunez4296 is offline
Programmer
AKA: Joseph Nuņez
FRC #4296 (Trident Robotics)
Rookie Year: 2013
Nunez4296 is an unknown quantity at this point
Rather than setting an IP address for your camera, since it is usb, write "USB 0". After that, deploy the code but check the "Enable Vision" box on the front panel of the Main.vi. From there, go to the dashboard and select what type of camera you are using, for us, we are using a logitec USB camera set for USB 0. On the dashboard, this would be "USB Camera HW".
The Eagle - By Alfred, Lord Tennyson
He clasps the crag with crooked hands;
Close to the sun in lonely lands,
Ring'd with the azure world, he stands.
The wrinkled sea beneath him crawls;
He watches from his mountain walls,
And like a thunderbolt he falls.
