Go to Post Its not the type of material you use, but how you use it... - jrocket567 [more]
Unread 14-02-2015, 15:48
zDrakon zDrakon is offline
FRC #3501
zDrakon is an unknown quantity at this point
ODROID Operating System outdated
Has anyone found a way to get a working eclipse on ODROID. The version of the operating system we have is outdated therefore does not have the necessary packages to install eclipse-pde apparently. It is too outdated to retrieve dependencies for eclipse packages.
Any links out there that give the most updated OS for ODROID U3? I tried hardkernel.com and the odroid "official" websites. Their links are outdated apparently. Thanks please help =D!
Unread 15-02-2015, 01:09
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Rookie Year: 2012
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: ODROID Operating System outdated
Trust me when I say this, if your using a vision system with odroid and opencv, don't use java...already tried that not fun to get working...I could not get it working but python works fine! And so does c++...if you know java well enough to do vision processing on an odroid, you can learn python and use that
