Go to Post As JFK said we did not do this because it was easy, we did it because it was hard. - Glenn [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 14-02-2015, 17:45
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
Rookie Year: 2011
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Talon SRX PID Not Running
We're trying to use the built-in Talon SRX PID loop to control our Elevator motor. We have a quadrature encoder that is correctly reading the position of the Elevator and we can verify that the ticks are increasing as the Elevator moves up. I think that I have done what is necessary in code, but the Talon isn't doing anything during closed loop control.
These are the results of a self-test after (as far as I know) enabling the PID control mode of the Talon.
Code:
The self test completed successfully.
TALON is enabled.
Mode : 1 : Position Close Loop
Applied Throttle : 0
Brake during neutral
CloseLoopError : 1300
ProfileSlotSelect : 0
Selected Device for Close Loop : 0 : Quad Encoder
Pos: -1
Velocity: 1
Quad Encoder
Pos: 0
Velocity : -1
A Pin : 0
B Pin : 1
Idx Pin : 1
Idx rise edges : 0
This is the code that I'm using to enable PID and change the setpoint:
Code:
elevatorTalon.changeControlMode(CANTalon.ControlMode.Position);
elevatorTalon.set(0.0);
elevatorTalon.setProfile(0);
elevatorTalon.setPID(0.00091054, 0, 0);
elevatorTalon.enableControl();
elevatorTalon.set(setpoint.encoderValue);
(The setpoint used was 1300 encoder ticks)
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
Unread 14-02-2015, 18:32
James Kuszmaul James Kuszmaul is offline
NEFIRST CSA
FRC #0971 (Spartan Robotics)
Rookie Year: 2011
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
Re: Talon SRX PID Not Running
Nothing strikes me as obviously wrong with your code.
However, I do have to ask: How exactly did you arrive at that P gain value? Per section 17.13 of the Talon SRX Software Reference Manual, the P gain is in units of throttle / sensor, where throttle is 0 - 1024 and sensor units are encoder ticks (same units as the 1300 you are seeing). This means that your code should cause the talon to apply a throttle of 1300 * 0.00091054 = 1.18 throttle (out of 1024), and it is not implausible that such a low throttle could get rounded to zero. Have you tried a larger P value, tried including an I or D gain, or tried increasing the error?
Edit: Just as a reminder, if you haven't already, be sure to read the Talon Software Reference Manual. It is quite comprehensive and can generally answer any questions you may have.
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
Unread 14-02-2015, 19:03
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
Rookie Year: 2011
My mistake, I went with the (incorrect) assumption that throttle would be normalized. The P term was based on doing a linear regression from known errors to certain motor set points but I had done that with a maximum speed of 1.0 at 1000? ticks. I feel like that is most likely the issue, I'll have to test it on Monday. Thank you for your help.
As a Mentor:
As a Driver:
