Go to Post You will find that most people in good companies are real people that share the same values and concerns as all of us. - ebarker [more]
Unread 14-02-2015, 18:19
Kyefer Kyefer is offline
FRC #1100
Kyefer is an unknown quantity at this point
DoubleSolenoid on LiveWindow error
When I try to view a DoubleSolenoid in LiveWindow, it repeated throws this error although the object still works in LiveWindow
Code:
Unknown error status at edu.wpi.first.wpilibj.hal.HALUtil.checkStatus(HALUtil.java:51)
edu.wpi.first.wpilibj.SolenoidBase.getAll(SolenoidBase.java:69)
edu.wpi.first.wpilibj.DoubleSolenoid.get(DoubleSolenoid.java:140)
edu.wpi.first.wpilibj.DoubleSolenoid.updateTable(DoubleSolenoid.java:201)
edu.wpi.first.wpilibj.livewindow.LiveWindow.updateValues(LiveWindow.java:167)
edu.wpi.first.wpilibj.livewindow.LiveWindow.run(LiveWindow.java:132)
org.team1100.Robot.testPeriodic(Robot.java:82)
edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:117)
edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:234)
Going into the code, the code
Code:
HALUtil.checkStatus(status);
is where the error is handled. Does anyone know what causes this and how to fix it?
