Go to Post That little 18 amp-hour battery has a really hard life in a FIRST robot. - eugenebrooks [more]
Unread 14-02-2015, 19:10
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
Rookie Year: 2011
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Selecting out autonomous mode
We have our auto modes in a case structure, with the selector being a double which is read from the dashboard. When we run auto mode, whichever number that was in the control when the code was deployed is the mode that it runs. Changing the number does nothing, disabling and reenabling simply runs the same auto again. Does anyone know why this is happening?
2015 MAR District Champions
Unread 14-02-2015, 19:23
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Selecting out autonomous mode
Try using an integer or an enum to choose between cases instead of a double.
Unread 14-02-2015, 19:30
nandeeka's Avatar
nandeeka nandeeka is offline
FRC #1868
Rookie Year: 2013
nandeeka is on a distinguished road
When are you reading from the dashboard? (Make sure that you are reading from the dashboard every time you start teleop instead of everytime the robot restarts)
Unread 14-02-2015, 19:31
The ride never ends
Rookie Year: 2011
We are using the built in functionality to read values from the dashboard
Unread 14-02-2015, 19:52
nandeeka's Avatar
FRC #1868
Rookie Year: 2013
Can you post your code?
Unread 15-02-2015, 11:37
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The question was not how, but when. When does the code read the value?
Unread 18-02-2015, 15:33
apm4242 apm4242 is offline
FRC #4242
apm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud of
Keep in mind that I'm pretty new to all this. This is how I did the autonomous switching this year.
File Type: pdf Autonomous Mode Selection LabVIEW Dashboard.pdf (143.4 KB, 46 views)
Unread 18-02-2015, 17:00
Kevin Phan's Avatar
Kevin Phan Kevin Phan is offline
College Student
FRC #0357 (Royal Assault)
Rookie Year: 2010
Kevin Phan will become famous soon enoughKevin Phan will become famous soon enough
Past years, my team used a hard switch to select different autonomous modes. eStop robotics currently has an expansion port add-on that will give you an auto switch plus more analog and digital pins. Understanding that you are using the dashboard and this being in a LabVIEW thread, there are two vis that are responsible for information transferring between the robot and dashboard. The write vi is what the value is being assigned. The read vi is taking the value that was assigned and outputting it. Make sure the name both on the robot and dashboard is the same, if they are not it will not recognize them. This means the write vi in your dashboard has the same name as the read vi in your auto independent in your robot project. Now I would make your numeric control vi for your dashboard to be represented as an integer, this is just to keep sanity. If your problem still persists, please take a screenshot of your code and put it up. If you are uncomfortable with that you can just pm me.
VEX & FRC Student Team Member #357 Royal Assault 2010-2014 "Dare Mighty Things"
2014-2019 Attending Drexel University Major:Electrical Enginnering
