Go to Post As a programmer, I am trying to use more 0's than 1's to save weight. - Jared Russell [more]
Unread 14-02-2015, 21:43
FRCteam5110's Avatar
FRCteam5110 FRCteam5110 is offline
Team Captain - Driver - Programmer
AKA: Caitlin Scroggins
FRC #5110 (Elks)
Rookie Year: 2014
FRCteam5110 is an unknown quantity at this point
Robot Moving When Enabled
Why does everything seem to go haywire just days before Bag Day?
I was testing the robot today, driving it with no problem. Then my team hooked up several Talons (SRX) and they were blinking Red and Orange (and the RoboRIO power light was red). In an attempt to solve the problem the Talons were removed and everything was wired back to KitBot configuration. I turned on the robot and everything lit up the correct color so I went to enable it just to make sure it still drove. Right when I clicked the enable button it started coming at me at a relatively good speed, I disabled the possessed robot. I placed the robot on blocks and tried again, the problem persisted.
Here is everything I've tried so far:
Restarting the robot (several dozen times)
Changing/Resetting Code (even through the code was never changed prior to malfunction)
Restarting the RoboRIO/Code (in driver station)
Checking all electrical connections
Looked in WebDashboard to see if it indicated a problem
I'm currently trying to get a priest to perform an exorcism but it is Valentines Day and we have a huge snow storm so they all seem to be unavailable currently.
Any suggestions?
I'd be more than happy to supply photos/videos.
Thank you for the assistance!
Unread 14-02-2015, 21:52
ATannahill ATannahill is offline
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
Re: Robot Moving When Enabled
Red/orange blinking lights on the Talon SRX means damaged hardware. The red power light on the roboRIO indicates a power fault. That would indicated a wiring problem with your new motor controllers.
For your current set-up have you tried resetting your controllers? When you have the driver station up try hitting F1 with the joysticks centered. If that doesn't work, you might try restarting the driver station computer.
Unread 14-02-2015, 21:53
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
Rookie Year: 2011
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Can you supply code?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 15-02-2015, 09:34
FRC #5110 (Elks)
Rookie Year: 2014
Somehow after just continuing to restart it over and over it worked and hasn't gave me the problem since.
Thanks for the help!
