Go to Post Scout so that you're not in doubt! - Mark Pettit [more]
Unread 15-02-2015, 12:58
Bluejackets's Avatar
Bluejackets Bluejackets is offline
Bluejacket Robotics
FRC #5464 (Bluejacket Robotics)
Rookie Year: 2015
Bluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to beholdBluejackets is a splendid one to behold
Using a 9v on LEDs
Been scouring the manual but still not sure.
Can we run a small bank of LED lights on our robot off of a 9v battery. It would be total separate for all other electrical circuits. Is it legal? It would sure save us some hassles. Thanks for all your help.
Unread 15-02-2015, 13:15
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Using a 9v on LEDs
R20 and R21 in the Game Manual address your question.
Unread 15-02-2015, 13:19
Bluejacket Robotics
Rookie Year: 2015
WE found that in R20 and R21, my question is does supplying 9v power fit unto the "Etc"
R 21 Additionally, batteries integral to and part of a COTS computing device or self-contained camera are also permitted (e.g. laptop batteries, GoPro style camera, etc.), provided they’re only used to power the COTS computing device and any peripheral COTS USB input devices connected to the COTS computing device and they are securely fastened to the ROBOT.
No batteries other than those allowed per R20 are allowed on the ROBOT, whether or not they are being used to supply power.
Does a 9v light system fit into the "ETC"
Thanks for all your time and help
Unread 15-02-2015, 13:39
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
You would have to convince your inspector that the LEDs are either a computing device or a camera, and that the 9v battery is integral to it.
Since they don't compute anything, and they are not a camera I don't think they fit the first part. Furthermore, I doubt that they came with the battery integrally installed so they therefore don't fit the second part.
Anyway, that rule only applies to COTS devices, not devices you make yourself.
This is my interpretation of the rules and is not official, but I hope that it helps.
Unread 15-02-2015, 13:55
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
I am a mentor, and can only read the manual and tell you what it sais as well, but as Domtech pointed out, the etc there applies to examples of when the the battery is an integral part and self contained within the COTS item (housed entirely).
I would be a little surprised if the LED's you want to run fulfill this requirement, so if the LED's can run off five volts do that, if they can't buy a 9V voltage regulator and run 12v from the pdp or the vrm (I would use the pdp, but I don't know what exactly your using the LEDs for) to the regulator then to the LEDs.
If they are wired with a 9v head, and you don't want to cut it off, buy another from radioshack or somewhere and pair them.
