Use a button to make a motor move a certain number of rotations
Ok I was curious to see if this would work for making a motor move an exact amount of rotations when a button is pressed, thanks.
Re: Use a button to make a motor move a certain number of rotations
It depends on how you set your motors in Begin.vi, and what type of motor controllers you are using. Most likely, this will cause your motors to run at full speed forward or backward, while the button is pressed.
If you are using encoders and configured Talon SRX's to use CAN and position control with proper PID values, you may get a twitch. You will need proper software setup, encoders, and good PID values to do what you want to do accurately. The drive reference contains data that will configure the various drive and motor vi's to interpret their inputs properly. By default, the maximum input/output is 1, which corresponds to a 100% forward or backward. Your ±3.76... input will be seen as a saturated maximum of 1. The default mode if you just open a can Talon SRX will be Percent Vbus, which works the same as PWM, and doesn't use feedback from an encoder. All of this being said, you can approximate the closed-loop control to do what you want with a sensibly low speed and a timer, but this will take a LOT of experimentation, and the results will be highly variable. |
What is the number of pulses per rev for the built-in encoders? I think the only legal motors that have built-in encoders have 7 pulses per revolution and a 71:1 step down through the typically attached gearboxes. Are these the ones that you are using?
If so, that could correspond to 7 x 4 x 71 = 1988 counts per revolution. The factor of four is because the encoder is quadrature, and has four registered pulse edges per pulse cycle. That means you would be seeking a count of approximately 7475. The math changes if you are using a different gearbox. Note that the numbers I am using are integers. You can't have fractional pulses. All of this assumes that you set the output type as position in Begin.vi, and that you have appropriate PID terms. |
You would put it as an input to the drive (where you have it), but you have to have the drive motors properly configured. One other thing, is that you need a little more logic to latch the value. The Teleop.vi runs approximately every 20 ms. As soon as you let go of the button, your input will be to drive the motor back to the 0 position. This isn't what you want.
If you intend to drive your robot completely with position commands, you will need a state machine that keeps track of the current values, incrementing and decrementing the intended position. It is much easier to drive in speed or voltage mode. |
Ok I think I'm starting to understand this, so would I put the 7475 number as distance per count in begin for the encoder? Past that I'm not sure how I can assign a button to work under that motor count for the encoder and the motor in teleop
Can you post the snippet of code from Begin.vi where you setup these motors?
#10
Your snippets are illuminating.
OK, here's the rest of the story. Unfortunately, you won't have a simple way of just sending a number to the motor controller, as you are using PWM Victors, which have no understanding of encoders or close loop modes. You will need to implement a PID control in LabView, where the encoder inputs are compared to your desired position. The outputs will drive the motor voltages up and down, until the desired position is realized. LabView has several built-in PID functions, and there are many threads here about how to use them. |
#14
You are quite correct. Those chunks of screenshot carry the same human-readable info, which is what I was after. |
