Go to Post If that track ball comes crashing into Exploding Bacon's robot there is literally going to be an Oink Oink BOOM!:yikes: - Koko Ed [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 15-02-2015, 20:55
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Resetting Jaguar Encoder Count
We are trying to reset the internal encoder count of a Jaguar to 0. This is supposedly possible to do using the enableControl(double encoderInitialPosition) function.
The Jag is generally being run in %Vbus mode. From what we understand, it's necessary to change the control mode to Position in order for the passed double to have any effect. This is supported by looking at the source code, which only packs and sends the encoderInitialPosition if the m_controlMode instance variable is set to Position. (CANJaguar.class)
We found an example of this being done in C++
Code:
CANJaguar::ControlMode oldMode = GetControlMode();
//printf("Reseting encoder on Jag [%d], mode %d\n", m_deviceNumber, oldMode);
SetPositionReference(CANJaguar::kPosRef_QuadEncoder);
ConfigEncoderCodesPerRev(pulsesPerFt);
ChangeControlMode(CANJaguar::kPosition);
EnableControl(0.0);
ChangeControlMode(oldMode);
EnableControl();
and wrote what would seem to be equivalent code in Java:
Code:
jaguar.setPositionMode(CANJaguar.kQuadEncoder, encoderCounts, 0, 0, 0);
jaguar.enableControl(0.0);
jaguar.setPercentMode(CANJaguar.kQuadEncoder, encoderCounts);
jaguar.enableControl();
but the next time the set method is called:
Code:
jaguar.set(0);
it throws a CANMessageNotAllowedException with the output: "messageID = 5", which is not documented anywhere.
Thoughts?
