Thread Tools |
Rating:
Display Modes |
pic: Compressor Backpack
Re: pic: Compressor Backpack
Off season project: T-shirt cannon.
Who you gonna call?
We disassembled our t-shirt cannon rally robot last season. We have plans for a new and improved one!
Are you suggesting we also make a hand held backpack T-shirt cannon? Last edited by bEdhEd : 16-02-2015 at 03:44. |
Our team made one of these off-board compressor/air pack deals a few years ago. We used a 5 gal. steel tank rated for 250psi and then a FRC legal compressor. We considered all rules and believed it to be legal. We had pressure blow-off's and dump valves on both robot and pack. Big Al promptly ruled it unsafe for numerous reasons.
In retrospect, it was an unsafe idea even though the system worked well at the time and we had built in extra safeties. Sacrificing safety just to save some time is not the best practice. |
What couldn't you do to fall within the rules? |
I've gotten sideways in this thread.
Let me start over. Lets turn to be a "how can I" vs "you fail" thread. You are smart, how would you make this work? I want to have a backpack to charge my robot. Assume, metal tanks. Do I need a cable to the robot to control the initial air load? Once the air load is complete, can / how do I load a remote robot? |
Are you talking:
1) in the pit/que right before a match? 2) At a FRC event, other than right before a match? 3) Outside of an event? #1 is not possible. #3 anything goes. #2 is the tricky question. For #2, I would make a removable air tank pack that can fit into/onto your robot. It should have 2 connections: 1) Connection to robot vent valve 2) Its own vent valve During practice, you can run with however much weight you want. While you are in que, you can tether and charge all the tanks you want. Or, even bring the robot charged to the practice field. For competition, you can remove the extra air tanks. IF you can get the LRI to allow you to run 2 compressors off field, the removable air tank pack could have a 2nd compressor mounted to it (with all the safety stuff). You would then need a connection to a second PCM, to power the 2nd compressor. Note: At the championship, I forgot if you had to pass inspection in order to use the practice fields. If so, then you can only run on the championship practice fields in competition configuration (without the spare air tanks). However, there were practice areas where I think you don't need to have passed inspection. Last edited by rich2202 : 16-02-2015 at 13:01. |
#10
Even then, I would have some questions about a potentially hot compressor being strapped to someone's back. It would be very easy in that situation to back up, bump into someone, and give them a nice burn to the arm, chest, back, or even face (of the individual was shorter than the one wearing the back pack). A better solution for carrying around an off board compressor would be something similar to a small toolbox. Put the compressor, gauges, relief valve and everything else in that and it's easily portable and provides some additional Safety from contact with hot parts. You could even get creative, cut a couple of holes for ventilation and power a few fans from a small battery to help keep things cool. Arrange things properly and you won't even have to open the toolbox. This is, of course, assuming a legal off board compressor set up, with one compressor, no onboard compressor, no storage, and everything controlled from the robot. I don't think using multiple compressors or having off board storage would be legal in any way at an event, even if it was just for pit and Practice field use. |
#11
We appreciate all of Al's input on our robot, matter of fact he saved us at Milwaukee last year. So we appreciate all of his efforts. But anyways if I remember correctly it had to do with the diagram in the rule book showing the off board compressor options. We read it as this is "what you need to have" while the rule was "this is only what you could have" off your robot for pneumatics systems. And since there were no tanks in the off board section of the diagrams, the tank was not allowed. |
#13
I would definitely ask it be removed from an event I am a LRI at and if I saw it as an RI I would immediately get the LRI.
I would not allow it to be used on the practice field because we need to maintain equality. If other teams see you using it on the practice field they could easily assume that you use it to charge the tanks on the robot before taking it to the competition field. A RI or LRI can not check and make sure that you do not use it before every match. Sometimes it is about perception. |
#14
We put together most of one a year ago on our team, but never bothered to get it firing. You'll probably need some bigger tanks and definitely larger tubing for maximum movability of your barrel.
#15
Looks like a Proton pack from Ghostbusters.
